05-03-2014, 08:25 AM | #1 |
Edelbrock block letter heads
My 41 originally sported a set of prewar Edlebrock block letter flatheads - last week I was going to have them refit - everything was installed and engine fired. The #2 cyl filled with water - we immediately switched it off with no damage.
We found a very small pin hole that was not evident prior to installation in the area above the inlet valve of #2 cyl. So when using original heads - have them pressure tested and magnafluxed ( for cast iron ) and zyglo ( alloy heads ) to save yourself time and money! I decided to procure a set of newly made Edlebrock block letter heads to replace my worn originals - I am very impressed with Edlebrocks quality and appearance. They are also made in the USA - just where they are supposed to be! Hope this cautionary tail helps one of you fellas out. Best John Last edited by 1963turnerjohn; 05-03-2014 at 09:41 AM. |
05-03-2014, 09:25 AM | #2 |
Re: Edelbrock block letter heads
I have a set also and an original pair that im restoring.
The new ones are very nice but I wish they would have tried a little harder to make them look like the old ones |
05-03-2014, 09:41 AM | #3 |
It would be nice if they were 100% per original , though most of the new made period heads have some deviations for any number of reasons - since I drive my 41, the new ones are perfect and of sound construction. I am retaining the original set for history sake, only as they belonged to the car originally.
It may be a good idea to pre-pressure check your orig set to see if they are sound prior to install - may save you from having the issue I went through. |
05-03-2014, 09:50 AM | #4 |
John, Why didn't you repair the pin hole and reuse the heads?
05-03-2014, 10:07 AM | #5 |
I contemplated welding and remachining the combustion chamber, but I have 2 reasons , I want to attend a local reliability run next weekend ( so time is tight ) and the cost would have been almost 1/2 that of new heads ( using a pro shops services ) / and since I drive my 41 the new heads offer a period look and reliability. I am keeping the orig set though and will get them fixed up
05-03-2014, 10:07 AM | #6 | |
Curious, what are the differences? |
05-03-2014, 10:09 AM | #7 |
Yes I’ve pressure checked (first thing always)
This started when I spotted a single one in the front window of a local thrift store. I went in and ended up with it for 50 bucks and started watching eBay for another single. So now I have a pair with little corrosion for cheap …. after years of looking at many very rotten pairs. |
05-03-2014, 10:12 AM | #8 |
05-04-2014, 08:16 AM | #9 |
Could you give me some info on Zygol mentioned in your post? Regards, Ray
05-04-2014, 08:38 AM | #10 |
Zyglo, long accepted as the standard industrial penetrant test detects cracks, pores, leaks and other defects open to the surface in solids - metallic or otherwise. Under the high-intensity Zyglo Black Light you see cracks and defects as glowing signals - even ones you'd miss entirely by any other penetrant test method.
05-04-2014, 09:49 AM | #11 |
Since I am a bug on having the real 'old stuff', the newer versions are not the same appearance wise. No big deal, but, in my own rules, I am only to use the old stuff. The ones I use are the script lettered ones. I bought a new set, but I was not happy to see that they were quite different. Over time, I found the original good heads...a lot of time searching and spending $$$...but I am happy ( crazy me ) The older ones have a much thinner fin and the script is smaller and not machined flat. Just thought someone could use this info also. Robert
05-04-2014, 02:51 PM | #12 |
Now don't forget to check piston to head clearance (.045/.050). This will improve the economy and increas throttle response. Might even let you use smaller jets .
05-07-2014, 06:42 PM | #13 |
Thanks for the info on Zyglo. Regards, Ray
05-09-2014, 06:15 PM | #14 |
