04-27-2022, 07:20 PM | #1 |
Trailer winch
I just purchased an enclosed trailer for hauling my Model A around. I would like to install an electric winch to pull the car onto the trailer. Looking at the options and brand choices i am overwhelmed. I think I want one with a wireless remote, but unsure of brand to buy or lifting ability. Any thoughts on this would be great.
Thanks |
04-27-2022, 07:34 PM | #2 |
Re: Trailer winch
I have a small Warn in my trailer. 2000 lb capacity, I think. Maybe one size bigger? You don't need 10k lbs to roll a car into the trailer. Consider a synthetic cable instead of metal, if your installation won't drag the cable over abrasive parts of the trailer. You'll also need a battery if your trailer doesn't already have one. Lastly, put a good sized metal plate underneath the trailer floor where you install the winch to spread the load.
I have winches on both my open and enclosed trailers. I haven't needed then often, but they are a lifesaver when I do. |
04-27-2022, 07:49 PM | #3 |
Re: Trailer winch
I mounted a 3,500 lb. ATV winch(12volt) and a 1,500 lb. Warn 120 volt winch in my enclosed trailer when I moved. I had electricity where I loaded and where I unloaded, so I only used the 120 volt winch. I moved 2 Model A’s and 4 Camaros, which it pulled with ease. The 12 volt was my backup and I had used that on my open trailer. It also worked fine for loading rolling cars.
04-28-2022, 06:44 AM | #4 |
Re: Trailer winch
I use Harbor Freight's wireless remote 2500lb. Works great for a sale price of $60. I put 1/4" backing plate on bottom side of floor.
04-28-2022, 06:46 AM | #5 |
Re: Trailer winch
buy a HF and get the warranty.
04-28-2022, 07:24 AM | #6 |
Re: Trailer winch
The other recommendation I would make is to 'lose' the wire winch cable and purchase the ¼" synthetic rope to replace the cable. We use the 10k rated cable like THESE and they are awesome at protecting your hands from cuts when handling the cable, and it makes wadding up the cable a breeze when you have winched-out the car and don't want to reel the cable back in at that moment. And, while you are at it, we have had very good luck with these type of Ratchet Straps which include the tie-back axle straps along with separate axle straps. |
04-28-2022, 07:54 AM | #7 |
Re: Trailer winch
I use an enclosed 8000# Warn winch with a remote and synthetic rope on my open tilt bed trailer. I also have an assortment of shackles and a turning block to extract dead cars from hard to get to spots. I've had the Warn for 30 years and after using an ATV winch on an ATV, I wouldn't bother with anything under 5000#.
No restorable Model A's were harmed in the building of this truck! |
04-28-2022, 01:15 PM | #8 |
Re: Trailer winch
This isn't what the OP asked about, but will throw it into the mix anyway. I had an old junk boat trailer with a good winch, so I mounted it in our enclosed car trailer. I can hand crank a car into the trailer with little effort. My doctor says I need to exercise more, because it's good for the heart.
04-28-2022, 06:35 PM | #9 |
Re: Trailer winch
Thank you for all of the input. I ended up buying a Bulldog model 15020R2 #4400 winch from a local supplier. It cam with a wired remote w/ 20' of line and 1/4" synthetic rope. A wireless remote is available for an additional charge ($50.). I purchased from amazon the tie downs Brent had recommended.
The trailer has a 4'x4'x1' hatch/storage box in the floor located centered toward the front under about where the engine on the model a will sit. Currently there is a spare tire there with plenty of room to spare. My question is should I mount the battery box there? or outside the trailer on the tongue ? |
04-28-2022, 07:39 PM | #10 |
Re: Trailer winch
If you mount it in the spare compartment, put it in a marine battery box and run a vent tube from the marine box to the outside air. Probably 1 1/2”- 2” tubing for the vent.
04-28-2022, 08:27 PM | #11 |
Re: Trailer winch
An inside battery location might be a PITA if you can't get to it with the trailer loaded and the battery takes a dump. JMO.
Making the simple complicated for over 30 years. |
04-28-2022, 10:16 PM | #12 |
Re: Trailer winch
I am thinking the outside location may be best. Battery acid and vapors cannot be good and most trailers I have seen have the box outside. It would be so easy to mount it inside, but where is the fun in that. Thanks again
04-29-2022, 01:41 AM | #13 |
Re: Trailer winch
Steve,
I use a ComeUp winch with a wireless remote, synthetic rope/cable and the 12V battery box mounted on the front wall inside the trailer (to prevent the battery from getting stolen, no extra holes through the trailer walls/floors and easy to keep clean underneath the box). The battery is located near a 110V wall plug (in the trailer), making it super easy to keep charged up (with a battery tender for example) when the trailer is attached to a land-line for electricity. The nice thing about the ComeUp winch is that the entire winch, mechanism, cabling, etc is all fully enclosed in a nice clean looking, compact, light-weight, corrosion resistant case. The wireless remote makes loading a car very easy and allows you to move freely around (or sit inside) the car to monitor the winching process. Here is a photo of my set-up, mounted inside the V-nose of my enclosed trailer: Brad in Maryland Last edited by Brad in Germany; 04-29-2022 at 09:10 PM. |
04-29-2022, 09:57 AM | #14 |
Re: Trailer winch
I have 2 of these HF winches that I have had great luck with. Both have been converted to synthetic rope.
https://www.harborfreight.com/automo...ope-56326.html |
04-29-2022, 09:57 AM | #15 |
Re: Trailer winch
Brad thank you for the photo. That is a beautiful setup. Where did you get the bracket that attaches to the wall for the battery? I am re-thinking setting it up inside the trailer
04-29-2022, 10:01 AM | #16 |
Re: Trailer winch
If you're concerned about "battery mess", consider an Optima for in trailer use.
04-29-2022, 09:36 PM | #17 | |
Re: Trailer winch
I put the battery in a plastic battery box to give it a clean look (and to contain any leak/residue that might form on the battery), but it still allows easy access to the battery terminals to hook up a battery tender. My battery also powers the LED strip lighting that I installed along the ceiling edges (the LED lighting power leads are buried in the wall and exit the wall in back of the battery box). Here you can see where I mounted the battery on the wall above the winch (and under the spare tire) in the front, V-nose of the trailer......with the LED strip lighting along the ceiling edges: Brad in Maryland |
04-30-2022, 06:47 AM | #18 | |
Re: Trailer winch
04-30-2022, 06:57 PM | #19 |
Trailer winch
I realize the OP already bought a winch.
But others may be looking for a winch and advice on how to mount & the battery. Weight rating is important But line speed is also important Some winches have too fast of a speed A wireless remote is also a must Harbor Freight is the best choice. If you seldom use your winch then there is no need to have a 12VDC permanent battery You can charge one up and put it in the trailer when you are going to need a winch Jim |
05-01-2022, 12:10 AM | #20 |
Re: Trailer winch
05-01-2022, 05:51 AM | #21 |
Re: Trailer winch
I sold Aluma trailers for 15 years before I retired. They are an excellent company to work with and they build very nice trailers. Every Aluma enclosed trailer is customized to the customers wants and needs.
05-10-2022, 10:53 AM | #22 |
Re: Trailer winch
One last question about winch installation. Should I put a fuse between battery and winch? Also battery cut off switch? I ended up installing battery outside trailer, just in front of where winch is on inside. I was thinking of installing 30amp fuse on positive side of battery inside battery box. Power winch sells these. Then I wasn't sure about a cut off switch inside trailer near winch. Any thoughts?
05-10-2022, 11:38 AM | #23 |
Re: Trailer winch
A circuit breaker might be better than a fuse, on a hard pull the current goes waaay up, you could run out of fuses in a hurry.
05-10-2022, 12:22 PM | #24 |
Re: Trailer winch
I made up this simple rig for emergency use on my trailer. No batteries, no cables etc. Just a high quality worm winch and a cordless drill/impact. The worm gear is something like 80-1 ratio using a snatch block, so the drill pulls a car up with no problem. If nothing else, the hand crank can be used.
