Old 10-28-2020, 12:20 PM   #1
Impsonaw
Default Lowering 46 Ford 4 door
Good afternoon fellas. I am new to this group but wanted to hear your ideas on the easiest and most cost effective way of lowering front and back of the car a few inches and making it level. Also will eventually be going the route of new whitewalls and wheels so any suggestions there would be great for better drivability. Thanks!
Impsonaw is offline   Reply With Quote
Old 10-28-2020, 12:53 PM   #2
drolston
drolston's Avatar
Default Re: Lowering 46 Ford 4 door
Plan A, cheapest. Remove 2nd and 4th spring leaves front and back. That should get you almost an inch at each end, and not adversely affect the ride and handling too much. You may occasionally hit the axle snubber.
Any greater lowering gets you into dropped axles, which is an expensive and challenging undertaking for the DIY home mechanic.
Plan B, maybe $400. Replace front and back springs with new reversed eye main leaf springs. That will drop the car about an inch and a half. You may still hit the snubbers, but the front spring shackle angle should be preserved near 45 degrees, which is important for anti-sway handling.
The empty-car stance should be raked a little nose down to allow for rear passenger and trunk loads. And most think a little rake looks better.
Old 10-28-2020, 01:29 PM   #3
Impsonaw
I have seen where some people get extended spindles. Do you not recommend this due to handling and possible rubbing?
Old 10-28-2020, 01:45 PM   #4
19Fordy
19Fordy's Avatar
What is an extended spindle? Do you mean dropped spindles? If so, they only work on cars with control arms, like a 50 Mercury.
Old 10-28-2020, 01:46 PM   #5
Impsonaw
Apologies. I ment shackles
Old 10-28-2020, 02:51 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
The go to method way back when, was longer shackles with sway bars added and maybe a 100 pound bag of sand in the trunk if needed.
Old 10-28-2020, 02:59 PM   #7
19Fordy
19Fordy's Avatar
Once you start "lowering your car" make sure you have good tire to fender clearance. Lower profile tires might help.
Old 10-28-2020, 05:48 PM   #8
meric42
meric42's Avatar
This is what I used on the front of my '41 and very happy with the results.
https://www.speedwaymotors.com/Posie...rop,37052.html
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
http://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 10-28-2020, 05:54 PM   #9
Impsonaw
Car looks great! What did you do to the rear to get the same kind of drop?
][/B]
Old 10-29-2020, 06:42 AM   #10
corvette8n
corvette8n's Avatar
You can also go to smaller diameter tires, I took the 16s off mine and went to lower profile 15” tires/wheels. Lowered everything about an inch or more.
Old 10-29-2020, 07:28 AM   #11
chap52
chap52's Avatar
In 1962 I went to Pep Boys and they had lowering shackles for my 46 Ford Woodie. I believe in 4 or 6 inch. Had to be cheap or I wouldn't have gotten them. Simple flat iron with holes in the ends for the bolts.
Old memories are great, most of them... Chap
Old 10-29-2020, 07:31 AM   #12
Impsonaw
That's great! Thanks for sharing! I'm going to look further into it. Who did everyone go through for making sure you got the best wheel and tire fit for your fenders and lugs?
Old 10-29-2020, 12:15 PM   #13
nickthebandit
IMO, longer shackles could lead to a swaying problem.
nickthebandit is offline   Reply With Quote
Old 10-29-2020, 01:37 PM   #14
drolston
drolston's Avatar
Lowering shackles were very common in early hot rod days; they are cheap and effective in getting the lower look. But they really degrade handling qualities.
And if you lower more that an two inches with long shackles, reverse eye springs, or removing leaves, you will probably have to cut down the rubber axle snubbers on the frame to avoid frequently bottoming out.
Old 10-29-2020, 02:20 PM   #15
meric42
meric42's Avatar
][/B]
That's just natural sag in the rear spring, the '41 is all original (except for the front spring and Bendix brakes) with about 40k on the clock, I swapped out the front spring out because the original had sagged so much that the shackles were contacting the front tires on hard lock.
Old 10-29-2020, 02:59 PM   #16
drolston
drolston's Avatar
I thought I was going to get a 2+ inch drop with the new reversed eye spring in the front of my '41 coupe. What I really got was less than an inch. That is because I was replacing a tired, work spring that had already sagged a lot.
Old 10-29-2020, 04:22 PM   #17
mercman from oz
mercman from oz's Avatar
Nice looking 1946 Ford Super Deluxe Fordor Sedan. Unfortunately, four door sedans are greatly overlooked. Love it.
Old 10-30-2020, 01:46 AM   #18
Tinker
Tinker's Avatar
Enjoy it for what it is. Its a great car!!! I went back and forth on lower vehicles. If you want to get it lower in the back cheap. Make some shackles. In the rear shackle lengths really don't matter that much. You can lower it a ton out back before you have to shave the bump stocks. Id rather use shackles in back then remove springs. Leave the front alone outside a drop axle. If you want in the weeds lowering, open your wallet. Nice car. I got away from the lower it to the ground after I drove it. But a bit off the back is no big deal. Try some long shackles I've seen them as long as 5" in back at shows. Next would be a reverse spring and shackles. We aren't running a race car I'm assuming.
Old 11-09-2020, 09:25 AM   #19
Impsonaw
Thanks guys for all of your responses! Now to start working on it
Old 11-09-2020, 09:33 AM   #20
big job
big job's Avatar
And I need to raise my rear 2 inches oh such is life and no bags of cement in the trunk
either spring has a good a arch to...
big job is offline   Reply With Quote
