10-26-2015, 09:27 PM | #1 |
Not Model A- Kohler engine trouble
Have a 12HP Kohler engine on a Gravely walk behind tractor. Starts and runs very rough spiting raw gas out of choke orfice. Carb has been serviced. The tractor has been sitting for several years (5-6?). Would a poorly seating valve cause this. Any and all help will be appreciated.
Sewall |
10-26-2015, 09:44 PM | #2 |
Re: Not Model A- Kohler engine trouble
Yes, do a compression test.
10-26-2015, 10:06 PM | #3 |
An intake valve that is hanging up can allow gas to spit out carb-also make sure carb. needle and seat is working properly-if not the carb will overflow and excess fuel can end up in combustion chamber or even in sump oil. Some Kohlers have a mechanical compression release that holds one valve open momentarily to ease pull starting
10-26-2015, 10:49 PM | #4 |
my first thought was stuck needle causing extreme rich condition. Is the plug wet with fuel? Hows the oil look/smell?
1929 Model AA - Need long splash aprons! |
10-27-2015, 03:12 AM | #5 |
Try some Sea Foam mixed with fresh gas without ethanol. I only use good gas without the corn crap in all my old cars and small engines.
10-27-2015, 06:52 AM | #6 |
10-27-2015, 06:57 AM | #7 |
i would start with what Tom mentioned... run sea foam through it
i have done this numerous times and it helped free things up.. i have to mix it with corn crap as straight fuel is not available near me.... |
10-27-2015, 08:18 AM | #8 |
Is there any one brand of gas that does not contain ethanol?
10-27-2015, 08:24 AM | #9 |
no, usually premium or midgrade does but you would have to check which stations do this.
honestly ive never had issues using ethonal gas as that's all we had for the last 25+ years in my area. I never do anything special either (most of it sits in the mowers all winter with whatever was left in it) start up just fine in the spring. i notice the lawnmower shops are gouging people selling non ethonal gas in a half gallon can for $8.00...
10-27-2015, 09:22 AM | #10 |
10-27-2015, 12:42 PM | #11 |
I'm going to guess yours is a K301. I'd suspect the carb is your problem. If not the needle and seat, then I would pull the float and see if it will float evenly in a container of water.
Below is a link to the service manual. PM me if you need help. I play with these single cylinder Kohlers a lot; mostly K321 and K341. I have a few carbs and parts. http://www.kohlerengines.com/onlinec...1346_c_all.pdf |
10-27-2015, 03:45 PM | #12 |
Previous post had link to operator's manual.
Here's the link to the service manual. http://gravelymanuals.com/pdf/Kohler...v_Man_0472.pdf |
10-27-2015, 07:55 PM | #13 |
Shell Premium has no Ethanol. If it's in your area. (Or Country!!)
JP . |
10-27-2015, 09:42 PM | #14 |
Well I really want to thank everyone for your replies. I was only able to do a compression test today and it was right at 130PSI. I don't know what it should be but sure is better than my A I will do some more tinkering and let y'all know what happens.
I'll get some good gas tomorrow and Sea Foam and see if that helps. Sewall |
10-28-2015, 10:14 AM | #15 |
The link provided is a great place to ask about this kind of engine and tractor questions;
http://www.smokstak.com/ Steam gas diesel big small etc |
10-28-2015, 10:37 AM | #16 | |
run! I put a new set of points in it and acted as you discribed in your first post. Timing is VERY crittical on the Kohler !....so I used my mag buzzer.. Dudley |
10-28-2015, 10:43 AM | #17 |
What's a mag buzzer?
10-28-2015, 02:14 PM | #18 |
It's an audibule tool that DOESN'T run current threw a magnetto. I also use it
on regular ignition systems, insteed of a test light.. |
10-28-2015, 03:15 PM | #19 |
I used to have a Gravely. It was a beast that could chew through CT brush to expand our yard into a previously wooded areas. With a very large and DANGEROUS circular saw blade replacing the cutting deck we could trim stumps flush with the ground. A fun machine well worth fixing.
10-29-2015, 08:06 PM | #20 |
Well, I got her done! Followed a lot of advice from y'all and locally and my Gravely is running good. I put a little oil in the spark plug hole and turned the engine over a few times. Then followed Tom's suggestion with good gas and Sea Foam. Installed a new bowl gasket. Don't know which worked the best (maybe all) but is now running good.
Thanks again for everyone for your help and ideas. Sewall |
