05-07-2020, 09:45 PM | #1 |
31 Model A rear end
Question, when replacing the gaskets on the axel housings after setting the gearing up what’s the best gasket sealing to use?
Thanks |
05-08-2020, 04:53 AM | #2 |
Re: 31 Model A rear end
I have never used a sealer on the banjo gaskets or the banjo bolts and never ever any leaks over 30 plus years . I oil the gaskets with a very light oil prior to fitting and removing refitting etc etc to set the ring gear mesh and preload .Be aware the banjo bolts are a precision item they are a machine fit in the trumpet ends and should not need sealer but maybe a dab of LOCTITE SI 5926 would do no harm up to you . I do have a car with one or two bolts with the trace of a weep, axle done years ago . Other posters might do it differently but this works for me .
John in big celebrations VE DAY Suffolk County England . |
05-08-2020, 07:58 AM | #3 |
Light coat of spray Permatex 80065 on both gasket & surfaces. This more a contact cement than sealant.
SOME sort of RTV on the bolts. And yes. High class fit bolts only. Joe K
Shudda kept the horse. |
05-08-2020, 08:30 AM | #4 |
Some folks still use Indian Head Shellac. Some just put a bit of grease on them. In any case, a person doesn't want to add any thickness to it if the carrier preload is good.
05-08-2020, 10:06 AM | #5 |
I don't use any.
05-08-2020, 10:29 AM | #6 | |
Below are a few pictures showing how the axle housing gasket surfaces should be repaired. Use a file on the differential housing to remove the 'proud areas' around each bolt hole, and then follow-up with a hand countersink to clean the perimeter. Don't forget to check run-out in the entire housing itself to ensure the hubs will be in-line with the centerline of the rear end assy. . |
05-08-2020, 11:12 AM | #7 |
After cleaning any burrs around the edges I use this stuff. It fills the voids and does not add to thickness. Looking at the web site I see it can't be sold in several states; This item has been restricted from sale in the following states: CA, CT, DE, IL, MA, MI, OH, and RI.
https://www.grainger.com/product/2GX...g!438996414705!
I know the voices aren't real but damn they have some good ideas! |
05-08-2020, 12:02 PM | #8 |
Must be good stuff if it can't be sold in CA.
05-08-2020, 01:35 PM | #9 |
Just about everything has some kind of warning on it now days.
05-08-2020, 09:37 PM | #10 |
Thanks for all the feedback
05-09-2020, 09:59 AM | #11 |
None.
