Old 07-15-2018, 12:38 PM   #1
modela4shane
Default Drum Tail Light Socket 1928
Any know or have a picture of how the two wires attach into the early socket assembly. Are the wires bare or do they have bullets on the end of the wires. Thank you for any help on this.
modela4shane is offline   Reply With Quote
Old 07-15-2018, 01:19 PM   #2
Gary Karr
Gary Karr's Avatar
Default Re: Drum Tail Light Socket 1928
There should be copper bullet connectors on the ends of the tail lamp and brake light wires. They simply plug into the bottom of the bakelite socket.
Gary Karr is offline   Reply With Quote
Old 07-15-2018, 01:42 PM   #3
modela4shane
NOT the wires that connect to the tail light harness but the wires that connect to the SOCKET assembly. They go into two holes in the insulator. Bullet ends, bare wire ends that use a set screw?? How are wires attached inside of the socket assembly? This is for the early DRUM style tail light.
Old 07-15-2018, 04:27 PM   #4
vern hodgson
They plug into the Bakelite socket on the tailite
vern hodgson is offline   Reply With Quote
Old 07-15-2018, 05:19 PM   #5
modela4shane
Thank you very much!!
