06-16-2018, 02:32 PM | #1 |
1936 Horn Rod Question
Can anyone shed a little light and educate me on 36 horn rods. I have seen some that are made of DIECAST and some that are PLASTIC. Could one be 1935 and the other 1936 or just a change in material from Ford. I just purchased one and have now discovered that its DIECAST. Will either type be correct for a 1936 Ford?
Thank you for any help. |
06-16-2018, 03:01 PM | #2 |
Re: 1936 Horn Rod Question
Hi Everyone, modela4shane, your question is a little confusing, care to post a photo of the part you are asking about?
06-16-2018, 03:29 PM | #3 |
I think you'll find the die cast ones are painted black and used in std models. The plastic ones are a brownish color and used in deluxe models. Both 35 and 36.
06-16-2018, 07:03 PM | #4 |
Thank you for the clarification Brian! I am guessing if i painted the DIECAST one to match my deluxe banjo steering wheel it would make it a deluxe. All the PLASTIC one's i find seem to be fragile and have cracks, so a std. diecast with correct color seem's to me to be the best? What do you guys think, or is there a distinct difference? Thank you for all the help!
06-16-2018, 08:50 PM | #5 |
I have never seen a 'DIE CAST" HORN ROD, NOR A PLASTIC ONE, on a 35 or 36 Ford. Are you sure you are using the correct nomenclature?
Why would you want to paint a horn rod??? It is not visible unless you have it out of the steering tube.
06-16-2018, 09:03 PM | #6 |
06-16-2018, 09:04 PM | #7 |
Shane, that sounds like a plan!! paint it and no-one will know the difference.
06-16-2018, 10:02 PM | #8 |
Thanks for all the help Brian! Much appreciated.
06-17-2018, 07:47 AM | #9 | |
Oh. Okay.
06-19-2018, 05:36 PM | #10 |
I've seen many 35-36 light switch/horn button & rod assemblies with a plastic light actuator disc molded over a diecast part that secures the rod. Have never seen an all die cast actuator disc. Here are pictures of some of the 35-36 light switch/horn button & rod assemblies that I have. I would really like to see some pictures of the all die cast discs. Please post them here.
06-19-2018, 08:28 PM | #11 |
I'm with JM 35 Sedan... I've never seen one that is entirely diecast. I would like to see a picture.
06-20-2018, 06:40 AM | #12 |
Here is a Ford Archive drawing showing the horn rod. It had cast aluminum or zinc frame with soybean or phenolic material moulded around it.
06-21-2018, 07:37 AM | #13 |
Don, thanks for posting that info. Down loaded that one into my 35 files.
06-24-2018, 11:33 AM | #14 |
06-24-2018, 11:50 AM | #15 |
Very interesting. There must have been another supplier!!! Back to the Archives??
06-24-2018, 03:31 PM | #16 |
Well I'll be darn, never saw one like that here in the states. Thanks for posting.
