Old 06-15-2013, 09:56 PM   #1
KGBnut
KGBnut's Avatar
Default Adding Dome Light to '30 Coupe
I'm re-doing the roof in my '30 Coupe. It was originally a Standard, but I have decided to add a Dome Light. My new roof wood came with the block to support the Dome Light, but no instructions as to where it goes.
There are four roof bows. Based on spacing, there are only two places it could fit. It looks like it could go dead center, between bows two and three. Or, it could go one more space to the rear, between bow three and bow four (which is the wider bow). Which is correct?
Also, the block for the Dome Light has a tear-drop shaped cutout. Does the opening in the cutout face forward or back? I assume the wires come from the front, so I'm guessing the opening should go toward the front.
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 06-15-2013, 10:07 PM   #2
Don S
Default Re: Adding Dome Light to '30 Coupe
If you are going to use it to read maps or ? it should be aft of the rib,but if you are going to be judged make sure it is placed accordingly Mine is aft of the second forward rib,directly over the center of the seat,Works for me.
Don S is offline   Reply With Quote
Old 06-16-2013, 08:08 AM   #3
1931 flamingo
1931 flamingo's Avatar
I'm thinking the wire comes up the rh door post and across. Someone more knowledgable will chime in I'm sure.
Paul in CT
Old 06-16-2013, 08:55 AM   #4
V4F
V4F's Avatar
i just use my dash lite .
V4f
V4F is offline   Reply With Quote
Old 06-16-2013, 09:47 AM   #5
TinCup
TinCup's Avatar
Here are a couple of pics from my interior last year.
TinCup is offline   Reply With Quote
Old 01-29-2018, 05:30 PM   #6
Richard Lorenz
I have a repro dome light that I bought many years ago for a '31 Coupe. I cannot figure out any way to physically attach it to the mounting board. The back (top) is perfectly smooth like the one shown in TinCup's second photo.
I might be able to build my own support bracket that I could JB Weld to the top of the dome light after I rough it up. Any suggestions?
Richard Lorenz is offline   Reply With Quote
Old 01-29-2018, 06:56 PM   #7
Kurt in NJ
Kurt in NJ's Avatar
screws go through the side if the housing into the wood block
