08-08-2019, 08:11 PM | #1 |
parts list: '31 fenders, running boards, etc.
Thanx in advance 'cause I know I'll get the answers I need from here.
I've inherited a 1931 Model A two door sedan. I saw the car last week and it's scheduled to be delivered to me next Tuesday or Wednesday. Unfortunately it had been partially disassembled. The fenders, running boards, etc., are missing. I've never had a Model A before and don't know what specific parts I'll need. Please fill in anything that I don't list that I'll need to put all this stuff back on the car. LF fender RF fender LR fender RR fender left splash apron right splash apron left running board right running board headlights and bar tail lights That much even a novice like me can figure out. I know that there must be many brackets and bolts and such that I'm missing in addition to the above. Would someone please list the rest of the parts I'll be needing? I'd like to begin acquiring these pieces. I'm guessing that buying a piece here and a piece there it probably will take me quite a while to collect all of this. Of course it would be quite a coup to find all of this at one time in one place. b-t-w; I searched and came up empty. If there's someplace I should have looked please direct me there. Thanx again.
atch (Mike Atchley) Columbia, Missouri <>< |
08-08-2019, 08:23 PM | #2 |
Re: parts list: '31 fenders, running boards, etc.
I'v got front&rear fenders,mount brackets if you can't find any closer.From a Murray 4door,will need a little work.Haven't thought about price.I'll try to get pix.You might ck berts model a.
08-08-2019, 08:27 PM | #3 |
Just a word of advice. I am in the process of doing a 31 Roadster and have found that repro rear fenders, runningboards, splash aprons fit quite well. However everyone I have talked to agrees that good quality repro front fenders don't exist. If at all possible find a pair of original front fenders that can be refurbished. Do you have front and rear fender and runningboard brackets? Bolt kits are available for runningboards, splash aprons and fenders and are worth buying. Keep asking questions as you go and it pays to establish a relationship with a reputable parts dealer. They can provide valuable advice.. Good luck!
08-08-2019, 08:40 PM | #4 | ||
Everything associated with fenders, running boards, splash aprons, etc., is missing. Thank you both for taking the time to read and respond.
atch (Mike Atchley) Columbia, Missouri <>< Last edited by atch; 08-08-2019 at 08:47 PM. |
08-08-2019, 08:53 PM | #5 |
Front fenders have a welded crack +- 3"outside edge,one rear needs a square patch 2.5"x3.5"probably for a light of some kind.Not sure about tudor to fordor but shouldn't be an issue.I'll see if i can get pix,Webb.
08-08-2019, 10:21 PM | #6 |
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
08-08-2019, 10:24 PM | #7 |
Model A/AA websites. when u first log on to this model A Section there are many vendors on a list. Contact Berts, Brattons, Snyders Etc they will send you catalogs for parts etc. Also visit www.mafca.com for more info and any local chapters in your area-Your local club will be glad to give you all the advice and probably more help then u need. Join your local Model A Club- ENJOY YOUR A!
www.whidbeymodelaclub.com |
08-08-2019, 10:26 PM | #8 |
08-08-2019, 10:34 PM | #9 |
Thanx all.
08-08-2019, 11:06 PM | #10 |
Atch : Thats good advice as to conacting a local Model A club. Those guys have tons of experience on restoring an A and can guide you down the right path. Do the homework first ,learn as much as possible before buying cast-off ,beatup junk . My advice ,having gone thru a similar situation ,is to buy the absolute best original pieces that you can find or afford. Repairing beat-to-heck ,rusted junk gets expensive quick. Buying things you dont really need is also prevented by learning from someone who has done it before
Thats my $0.02 worth and good luck on building the A Stan |
08-08-2019, 11:46 PM | #11 | |
I agree that if you can get in touch with a Model A Club that is near you, they will usually be very helpful. Bert's Model A in Colorado has a very good stock of new as well as good used parts and are also very helpful. How about posting some pictures? Good luck with your new project. Chris W. Last edited by CWPASADENA; 08-08-2019 at 11:47 PM. Reason: ELABORATION |
08-09-2019, 10:07 AM | #12 |
You might need one of these: https://www.snydersantiqueauto.com/P.../model-a-books
09-11-2020, 12:50 PM | #13 |
Sorry to resurrect an ancient thread.
I found someone building a hot rod out of an old restoration and bought everything I needed. I still haven't began putting it all together; I'm still working on my '48 Ford panel truck. Thanx for looking. Just put this up in case down the road someone found the thread and had the parts I was looking for. This will save him/her the trouble of responding.
09-11-2020, 04:43 PM | #14 |
I wouldn't ever try keeping my PicUp if it wasn't for a local Club.
