08-05-2017, 09:21 PM | #1 |
Large axle nuts
I'm replacing the rear axles in my 41. In my Tardell service and rebuilding guide, the book shows two sizes of castellated nut - regular and large
I'm know a regular nut is OK, but a larger nut has a certain appeal (my current axles has been reworked to a smaller 9/16 UNF nut and it just won't hold - bad threads). What year/model are the larger nuts from? |
08-05-2017, 09:41 PM | #2 |
Re: Large axle nuts
I would contact Roy Nacewicz Parts, (734) 654-9450, fordbolts.com. He will know the answer and probably have them in stock. Based on his reputation if all he has is repros they will be the same strength as the originals.
Charlie Stephens |
08-05-2017, 10:56 PM | #3 |
Re: Large axle nuts
I believe the large axle nuts are post war, so 46-48. They are getting harder to find.
08-05-2017, 11:39 PM | #4 | |
Re: Large axle nuts
08-06-2017, 05:47 AM | #5 |
Re: Large axle nuts
I have that information in my PC at the office but not there today. I recall that they both have the same internal thread size (which is obvious since they both fit the same axles) but the older version was smaller across the flats. I believe that they had the same height. I'll try to get back to this thread later.
08-06-2017, 10:15 AM | #6 |
Re: Large axle nuts
08-06-2017, 12:24 PM | #7 |
Re: Large axle nuts
Almost all the nuts from the vendors are too soft. It is worthwhile to seek out good Ford used ones large or small. I would definitely test Speedway nuts with a file.
John |
08-06-2017, 12:40 PM | #8 | |
Re: Large axle nuts
Roy , IMO, does not sell inferior/soft metal nuts. And, you can actually talk with him for any information regarding wants/needs. And, his parts are reasonably priced ! |
08-06-2017, 02:17 PM | #9 | |
Re: Large axle nuts
All the Ford axles/nuts are 5/8-18. The original Ford spec on the nuts is S-18 "case hardened". I doubt most/all aftermarket nuts meet this spec. New or used OEM Ford nuts would be best. Either the small 15/16" (32-38) or large 1 1/4" (39-48) nuts will work fine.
Those who do not move do not die, but are they not already dead? Last edited by John R; 08-06-2017 at 02:23 PM. Reason: clarify |
08-07-2017, 06:45 PM | #10 |
Re: Large axle nuts
Thanks all. Had a good chat with Roy - very helpful. Hardware is on the way.
08-07-2017, 08:13 PM | #11 |
Re: Large axle nuts
Sooooooooo..........does that mean that Roy has the good, hardened nuts in stock? Don't leave out the details! DD
08-08-2017, 10:43 AM | #12 |
Re: Large axle nuts
Roy is the guy to go to. He is most helpful and has very good products.
Royal |
08-08-2017, 11:26 AM | #13 | |
Re: Large axle nuts
http://www.ebay.com/itm/FORD-V-8-RR-...NWd05t&vxp=mtr |
