02-14-2017, 08:40 AM | #1 |
1933 Ford V8 Oil Pump Screen Cover Gasket
Where can I find a gasket for an original style pump? I found a new screen at Macs (model A type B-6623), but can't seem to find a gasket for the screen cover. The gasket offered by them is oval while the original is round 2 3/4".
02-14-2017, 09:22 AM | #2 |
Re: 1933 Ford V8 Oil Pump Screen Cover Gasket
Don't recall ever seeing a gasket between the screen and the cover.
Perhaps this will help you in pointing it out.
02-14-2017, 10:34 AM | #3 |
Yes the original 32-34 oil pumps do have the gasket. They can be made if you have a gasket circle cutter.
02-14-2017, 11:26 AM | #4 |
02-14-2017, 01:02 PM | #5 |
I have these in stock
02-14-2017, 09:22 PM | #6 |
02-14-2017, 10:26 PM | #7 |
The NOS or NORS versions made of cork more often than not have shrunk and will not fit over the screen and even if carefully worked will split.
