09-18-2016, 07:25 AM | #1 |
1933 Spring Repair in Hudson Valley - NY
Does anyone know of a reputable spring repair shop that can install replacements main leaf springs and new shackles near Poughkeepsie, NY? I would do it myself but figured it wasn't worth taking a chance for the cost.
09-18-2016, 10:26 AM | #2 |
Re: 1933 Spring Repair in Hudson Valley - NY
Hey Doug,
This is Tony from Kingston. There is, or was, a spring shop in Newburg called McDonald & McDonald. I used them as far back as the '60s. They might have old stock or can make. Good luck! Tony
Life is too short to restore every car, fix 'em and drive 'em the way that they are. |
09-18-2016, 10:42 AM | #3 |
Google shows a place in Danbury,,,
09-18-2016, 12:53 PM | #4 |
Thanks Tony & Scrapiron,
I'll try McDonald & McDonald first. I tried researching on AOL and couldn't find anyplace near. Should have tried Google. I'll be buying main leafs directly from Eaton and hopefully they will be willing to just install them. |
09-18-2016, 02:10 PM | #5 |
The folks that fabricate springs and the folks that work on installation of suspension parts may not be the same folks! I always have a local shop fabricate whatever spring set up I am wanting, but I install them myself.
09-23-2016, 11:25 AM | #6 |
09-23-2016, 11:46 AM | #7 |
Installing the spring itself is fairly simple and would take almost nothing for a shop to do. So I'm guessing they are referring to removing and installing the shackle bushings? To bad you don't know someone in your area that would help you do it.
The original springs were very stiff (at least to my way of thinking) and leaves are often removed to "soften" them up a little. Are you sure you want to go to the effort to raise the body height one inch? |
09-23-2016, 02:17 PM | #8 |
I think bringing your own springs to a spring shop would tend to piss them off and end up costing you. Find someone who knows old cars and will work on it.
09-23-2016, 02:21 PM | #9 |
09-23-2016, 02:57 PM | #10 |
Smaller communities away from urban areas generally only have suspension or front end shops that specialize in work of this nature. I would look for a shop that does trucks since they are familiar with straight axles and mounting work for them.
There is a spring shop on my side of San Antonio but all they do is make springs up from their own stock. They can make them any way you want them so a person would bring an example for replication to them to insure for fit. These type shops are likely few and far between in smaller communities. |
09-23-2016, 04:26 PM | #11 |
Doug 845 I have a 33 spring with the tapered ends if interested? I will bring it to Hershey let me know. I believe I replaced one of the leaves, What model do you have? I have shackles also.
Assumption is the mother of all foul-ups. |
09-23-2016, 06:55 PM | #12 |
I called the local shop and they had no problem with installing Eaton springs since they said they probably didn't have ones that would fit anyway. I would like to have the spring removed and greased, shackles replaced, and a mainleaf installed front & back. I will probably do the job myself at this point. I'll just have to find an affordable leaf spreader for the front & back.
09-23-2016, 07:24 PM | #13 |
Doug,
Check your PM's |
09-23-2016, 07:28 PM | #14 | |
09-23-2016, 07:36 PM | #15 |
09-23-2016, 07:37 PM | #16 | |
09-24-2016, 05:41 AM | #17 |
As far as replacing the main leaf, I've read a lot of posts here on leaf springs and shackle replacement and based upon those posts it seems like the best thing to do. One Barner on here (Kube) suggested it in one of his older posts since the spring is all apart anyway. Eaton only charges $100 for the front and $150 for the rear. That is cheap insurance in my opinion. I was thinking about using 5th wheel grease but now see that "Slip Plate" would be the proper product to use.
09-24-2016, 09:01 AM | #18 | |
I replace (only) the main leaf when that is my only option. That happens very rarely. I don't tend to do anything "on the cheap". Thus, I nearly always replace the entire spring with NOS. New old stock - meaning FORD, not Eaton, or any other after market manufacture. Ford springs (NOS) bring the car back to the designed height - something I require of my restorations. I do strip and powder finish each individual leaf prior to reassembly. The bottom line I suppose is what you require from your efforts. If you are willing to utilize an Eaton (or other than Ford) spring, apparently authenticity is not important to you. In that case, the Eaton main would probably serve you just fine. Remember that all of the leaves of your old spring are fatigued. Replacing the main leaf will bring back some of the ride height but certainly not all. Also, utilizing old leafs will not restore the authentic handling characteristics. Are those things important to you? If you do use old leafs, be certain to finish back all worn leaf "grooves" as well as replacing the perch pins - that's important.
09-24-2016, 09:07 AM | #19 |
Kube, I sure understand the authentic/original aspect you are referring to, but it almost sounds like Doug is considering it a safety issue. IF the spring has ware or damage it could be, but a spring in good condition? I use original springs in good condition all the time (NOT in authentic restoration projects!), do you consider that a safety issue?
09-24-2016, 09:18 AM | #20 | |
Still, I would replace the perch pins for certain and grind back any grooves. Those two processes would help the handling characteristics, again, in my opinion.
09-24-2016, 11:41 AM | #21 |
Thanks for all the feedback. My primary concern is safety. My secondary concern is ride height. My third concern is originality. If I could find Ford NOS springs I would buy them instead of Eaton if the cost is within reason.
09-24-2016, 12:23 PM | #22 |
Doug......Check with Fred Wilner at Southside Obsolete for NOS ANYTHING. He SHOULD have your NOS spring. His info below in the 1st link! Fred is also a member here on the 'Barn and goes by barnfind08. You could PM Fred by clicking on the second link. DD
http://www.southsideobsolete.com/Sou...e/Welcome.html PM to barnfind08....Fred Wilner, below! http://www.fordbarn.com/forum/privat...do=newpm&u=104 |
10-12-2016, 12:14 PM | #23 |
I called back Eaton to order the main springs and was told that he quoted me the wrong price for the rear mains. Instead of $150 each it was now $200 each. For both of my cars that adds another $100 to the bill. I think I'll stick with the originals for now and save myself $660 (fronts, rears, & shipping). Hopefully there are no broken pieces when I disassemble them.
10-12-2016, 12:34 PM | #24 |
Where I am located (center of the US) to have a main spring fab'ed at a local spring shop runs around $20. Now that is for a stright front spring! I have not had a 33 rear spring made, but $200 seems a little steep to me. I would think more in the $100 range would be more appropriate.
If your rear spring is not worn or damaged that would be a good approach. It you are wanting more arch in the spring that is easily accomplished at home or by a spring shop |
