Old 04-17-2015, 08:41 AM   #1
Glenn of northport
Glenn of northport's Avatar
Question Roll out garage flooring
Has any one used a roll out garage flooring called G - floor you can see it on elitegaragefloors.com I am thinking about using it and I am wondering how it holds out
Glenn of northport is offline   Reply With Quote
Old 04-17-2015, 09:29 AM   #2
Mitch//pa
Default Re: Roll out garage flooring
i have the roll out coin flooring in my 3 car garage. it does slip some in the forward direction when driving a car in the bay from stopping. to eliminate that issue i put a metal floor divider strip at the entrance of each stall using masonary fasteners. i did want to glue the whole thing down in case i wanted to remove it and clean it outside...
i am very happy with it
Old 04-17-2015, 02:05 PM   #3
mlp623
mlp623's Avatar
I realized a few months ago that there are other forums linked at the bottom of FordBarn. One is "The Garage Journal". I found a lot of good info on shop lights and tools there. There is a whole forum just on garage floors too. May be worth a look.
http://www.garagejournal.com/forum/f...splay.php?f=20
mlp623 is offline   Reply With Quote
Old 04-17-2015, 06:00 PM   #4
SeaSlugs
SeaSlugs's Avatar
looks like neat stuff, looks similar to the fatigue mats we have at work. these are constantly getting machine coolant and oil dripped on them daily, they do get pretty nasty over time but do hold up well. they can be slicker than ice when a bit of oil gets on them - might want to keep that in mind and arent the easiest to clean up. several paper towels and a good degreasing cleaner spray does the trick it seems.
i wonder if they would leave tire divots over time if you dont move the model a for awhile...
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 04-17-2015, 06:00 PM   #5
fiddlybits
fiddlybits's Avatar
I use the ribbed in the everyday garage to help keep the junk that comes in on the car contained and easy to push back outside.
fiddlybits is offline   Reply With Quote
Old 04-17-2015, 07:06 PM   #6
foxfire42
foxfire42's Avatar
I put one in using diamond PVC tiles. BAD idea although it looks great. It kills your knees if you have to get down on the floor for any reason.
foxfire42 is offline   Reply With Quote
Old 04-17-2015, 09:24 PM   #7
Tom K.
I have had the pebble finish G flooring in my garage 3 years now. Fuel is the only thing that seems to affect it. Oil and glycol no problems. Have to put a piece of wood under jack stands or they will leave marks. Mine is not glued down so it shrinks about an inch in the Mich. winter.
Tom K. is offline   Reply With Quote
