10-07-2014, 10:21 AM | #1 |
control throttle assembly
Will the a9725 used on 28-31 work on 32 model b block?
10-08-2014, 10:14 AM | #2 |
Re: control throttle assembly
This is a very simple question The control throttle assembly bolts on the back of the block fire wall side with 2 bolts gas petal on one side other end rod goes to carb--using a model b engine can I use same control unit???
10-08-2014, 10:24 AM | #3 |
Yep....
10-08-2014, 10:25 AM | #4 |
Glenn of northport,
The answer would be Yes, any of us that use a Model B Engine Block in a Model A chassis use the standard Throttle Assembly. Darryl in Fairbanks 20 degrees here in the Interior |
10-08-2014, 11:20 AM | #5 |
Thank you Thank you 50 in Northport MI no snow yet
10-08-2014, 12:02 PM | #6 |
MIKE (mikeburch) |
