Old 05-14-2014, 09:55 PM   #1
trvguy
trvguy's Avatar
Default Intake manifolds
Will 49 thru 53 intake manifold fit on a 48 merc engine with out modifying anything?
Thanks for any help.
trvguy is offline   Reply With Quote
Old 05-14-2014, 11:59 PM   #2
Karl Wolf
Karl Wolf's Avatar
Default Re: Intake manifolds
Yes, may have to plug the holes for breather and oil fill in the front of the manifold... I use freeze plugs upside down- they look better that way... I used one for pcv valve...
May want to keep the fuel pump push rod for the manifold you're gonna use...
Karl
Karl Wolf is offline   Reply With Quote
Old 05-15-2014, 05:34 AM   #3
JWL
It depends on your definition of "fit"??? There will not be a distributor vacuum access point, there will be fewer attachment holes, there will be unneeded crankcase vents.
JWL is offline   Reply With Quote
Old 05-15-2014, 06:21 AM   #4
Mr_Coupe
Mr_Coupe's Avatar
That about sums it up. LOL!!
Mr_Coupe is offline   Reply With Quote
Old 07-10-2016, 10:47 AM   #5
jrvariel48
jrvariel48's Avatar
Karl
Karl do you have pictures of the plug install? Can you tell me which freeze plugs you used? I'm asking because I'll be running a late intake on an early motor
jrvariel48 is offline   Reply With Quote
Old 07-10-2016, 11:03 AM   #6
JSeery
JSeery's Avatar
Wouldn't it be easy to measure the hole? You can get freeze plugs in about any size.
Old 07-10-2016, 12:27 PM   #7
jrvariel48
jrvariel48's Avatar
You can get pretty close, I ordered some today. If they work out, I'll post the details.
Thanks,
Joe
Thread Tools
Display Modes
