12-20-2017, 12:48 PM | #1 |
1940 vs 1948 Rear Backing Plate Differences?
What are the Visual Differences between the 1939-'41 Ford style rear backing
plates and 1946-'48 Ford style rear backing plates? Is the E-Brake hardware the Same for Both styles? Thanks in advance. |
12-20-2017, 12:57 PM | #2 |
Re: 1940 vs 1948 Rear Backing Plate Differences?
E brake stuff is the same (I'm pretty sure).
Early have two removable eccentric bolts at the bottom with 1/2" threads and 3/4 af nuts on them. later have two fixed studs rivetted in and splitpins (cotter pins) on the inside). Mart. |
12-20-2017, 01:09 PM | #3 |
The adjusters are a sure give away. 46/48 have only two.
Cobbie |
12-20-2017, 02:54 PM | #4 |
The levers for em brake are different.
12-20-2017, 06:04 PM | #5 |
Besides the previously mentioned fixed and adjustable lower studs, there are a couple of other differences between the early and later styles. There are a different style of clips (and the way they are attached to the backing plate) at the mid-point of the shoes, and the later style also has 6 raised shoe contact points. A couple of these pictures are of front backing plates but they show the same differences as the rear will have. Not familiar with any differences with the parking brake.
01-05-2018, 10:13 PM | #6 |
