Old 01-08-2015, 02:31 PM   #1
some mech 3
Default 4 cycle, L head
I am not an expert on the Model A, but I do know more than the average bear. I have owned three A's, and presently have a 1931 standard coupe and an unassembled 1931 standard roadster. However, I am ignorant of the designation: L head. DeAngelis uses this term and I have seen other references to it. Does the L refer to the arrangement of the cylinders, the shape of the block, etc? I have no clue and would appreciate someone educating me. Thank you in advance.
[email protected]
some mech 3 is offline   Reply With Quote
Old 01-08-2015, 02:52 PM   #2
emf
emf's Avatar
Default Re: 4 cycle, L head
It has to do with the relationship of the valves with respect to the piston/connecting rod. Picture the piston/rod in a vertical position with the both valves to the side and top of the piston travel. sort of like this:
________
l
l
l
l
l
Or an upside down L. An F head has one valve (usually exhaust) to the side and middle with the intake at the top (usually overhead). Hope that helps.
Frank
l
emf is offline   Reply With Quote
Old 01-08-2015, 03:08 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
And a T block would have intake valves on one side of the piston, and exhaust valves on the other side. That's a T valve arrangement, and not the Model T Ford.
Old 01-08-2015, 03:12 PM   #4
pooch
pooch's Avatar
And what alphabetical letter would you give a 20/s harley with a sidevalve exhaust and overhead valve inlet.
edit, googled it....F head.
pooch is offline   Reply With Quote
Old 01-08-2015, 03:27 PM   #5
Patrick L.
Patrick L.'s Avatar
Originally Posted by pooch View Post
Ans what alphabetical letter would you give a 20/s harley with a sidevalve exhaust and overhead valve inlet.
Inlet Over Exhaust [ IOE ], or, also known as F head. There are few engines with the opposite configuration [ EOI ] .
Old 01-08-2015, 04:32 PM   #6
some mech 3
Frank, Tom, Pooch, and Patrick: Thank you all for your input to my question. They were very good answers, and I no longer am ignorant; at least on this matter.
Sam
Old 01-08-2015, 04:36 PM   #7
some mech 3
Frank, Tom, Pooch, and Patrick: Thank you all for your input to my question. They were all very good answers. I am no longer ignorant; at least in this matter.
Sam
Old 01-08-2015, 05:05 PM   #8
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Now all you have to do, is figure out how not to double post! (Smiley face)
Old 01-09-2015, 11:15 AM   #9
some mech 3
Chuck Sea/Tac: My wife and I enjoyed your suggestion.
Sam
