Old 09-21-2010, 10:59 PM   #1
Dave in Boise
Dave in Boise's Avatar
Default Head marking identification please
Hi Laa,
i am putting in a motor in one of my rigs, and I noticed it has some markings on the head that i had not paid attention to before. I have no background, other than it's been on this engine for a while and seems to run fine.. Here is a picture. it says A6050, has an Mc in a rounded triangle and a 4 below.. Any idea on the make, model or compression?
Hope the Pic turns out..
Thanks as always! - Dave in Boise
Dave in Boise is offline   Reply With Quote
Old 09-22-2010, 03:33 AM   #2
Tudortomnz
Tudortomnz's Avatar
Default Re: Head marking identification please
A 6050 is Ford part number for 'cylinder head'. '4' sometimes appears on heads with 'S' which may refer to 'service ' part.
Tudortomnz is offline   Reply With Quote
Old 09-22-2010, 08:06 PM   #3
glenn in camino
glenn in camino's Avatar
It's aftermarket. If you're not building a fine point car, use it.
Old 09-22-2010, 08:10 PM   #4
glenn in camino
It's aftermarket. If you're not building a fine point car, use it. It will work fine although the new Snyder heads, the old BF. heads, or a stock B head will give you better compression and more power.
