08-29-2010, 05:29 PM | #1 |
speedometer cable questions
I'm new to the Model A. I have a 1929 Sport Coupe in which I have a jumpy speedometer. Driving at a constant speed the the speedo will jump back and forth 35-45 etc. The previous owner had a outer original cable and an inner cable in good condition that was not installed. Outer cable 61". Inner cable 62 1/8 ". I lubed it with spray lithium grease. Kept the routing smooth. I have read the other posts on this topic on this forum. I don't know if this is the original cable as the previous owner has passed on. I see the advice to use graphite based grease. Is lithium grease a bad substitute? The cable spins freely when not installed. It is slightly tighter when in the speedometer but spins. Ideas and helpful suggestions would be appreciated. Thanks. Jim
08-29-2010, 05:44 PM | #2 |
Re: speedometer cable questions
right now the speedo head itself needs to be cleaned,the old grease in it has hardened and is binding up the speedo shaft, you can pull the flat plug on the side of the speedo and carefully remove all the old grease, wd 40 works good, just be careful of the numbers on the dial, i would send it out to have it cleaned and repaired, it will be cheaper in the long run
08-30-2010, 07:57 AM | #3 |
Do a Fordbarn search on speedometers and cables and you will find a number of threads addressing your question. Gar Williams
08-30-2010, 12:24 PM | #4 |
Paul in CT |
