Old 08-30-2012, 01:29 PM   #1
Hivolt5.0
Hivolt5.0's Avatar
Default Y-block coil
Question, I have a 312 in my '57 Ranchero still running a points ignition. Eventually I want to change over to the pertronix ignition but I just don't have the funds right now. However, I have a nice chrome MSD coil from another project and I was wondering if I could use it with my points ignition?
thanks for your insight,
David
Hivolt5.0 is offline   Reply With Quote
Old 08-30-2012, 04:14 PM   #2
franksford
Default Re: Y-block coil
make sure it's for points and not electonic and dose it need a resistor? Frank
franksford is offline   Reply With Quote
Old 08-30-2012, 04:26 PM   #3
Hivolt5.0
Hivolt5.0's Avatar
Hmmm, well. I bought it from a parts store off their "performance" do dads shelf. The coil wire connection is the female type, if that makes any sense, like the factory coil. I don't remember if the package said if it was for points or electronic.
Old 08-30-2012, 07:31 PM   #4
rick55
rick55's Avatar
All MSD coils should have a parts number. It is probably a 8200 ( the only chrome coil in their catalogue) and is also known as Chrome Blaster 2. When used with points a ballast resistor is required but is not necessary when used with electronic ignitions. If in doubt use a ballast.
Regards
Rick
West Australia
1958 Ford Mainline Utility, 1955 Ford Tudor Sedan
Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young. The greatest thing in life is to keep your mind young.
Henry Ford
rick55 is offline   Reply With Quote
Old 09-02-2012, 04:08 PM   #5
Hivolt5.0
Hivolt5.0's Avatar
Regards
Thank you for the information. I already have a ballast in the circuit so I think I'll give the coil a try. Should I open the gap on the plugs any???
Old 09-02-2012, 11:20 PM   #6
GREENBIRD56
GREENBIRD56's Avatar
Since you still have the points - I wouldn't be opening the plug gap.
The Y's reportedly don't show any advantage to the wider gap when on the dyno - even when the ignition is "built". That being the case - there is no need to stress the insulation of the cap, wires or coil.
GREENBIRD56 is offline   Reply With Quote
