Old 09-08-2015, 02:57 PM   #1
grantsauder
grantsauder's Avatar
Default Fender Bead Wire
Greetings: I'm just starting to repair my rear fenders for my 1930 Tudor. Both original fenders are torn in one place each and the wire broken. How do I fix these tears and what is the diameter of the bead wire. I hope to have the Tudor on the road next May.Thanks in advance. Grant
grantsauder is offline   Reply With Quote
Old 09-08-2015, 07:00 PM   #2
Jeff in BC
Jeff in BC's Avatar
Default Re: Fender Bead Wire
Grant
Maybe this will help a little:
http://www.lionsgatemodelaclub.com/Tech_Sessions.html
Jeff
Jeff in BC is offline   Reply With Quote
Old 09-08-2015, 08:06 PM   #3
Jerry in Shasta
Jerry in Shasta's Avatar
In addition the the above site you can find spring wire at hobby stores that to cater remote control planes do it your self guys.
JB
Jerry in Shasta is offline   Reply With Quote
Old 09-08-2015, 09:41 PM   #4
Tinbasher
Tinbasher's Avatar
#9 Galvanized fence wire is perfect. Available at most hardware or farm stores. I've been using it for year for beaded fenders. Nice because it's galvanized.
John Poole
Tinbasher is offline   Reply With Quote
Old 09-09-2015, 07:18 AM   #5
C26Pinelake
John Poole
Very reasonably price by the small or large roll at your TSC store! Wayne
C26Pinelake is offline   Reply With Quote
Old 09-09-2015, 09:27 AM   #6
Jay's Model A's
Location: New Braunfels, Texas.. Member of Alamo A's, MARC & MAFCA
The ire size for proper fender replacement is #11'. That's a little smaller than the #9 found at most farm or lumber supply houses...My recommendations are to peel back the wrap around (Bead) 12 to 18inches on both sides of the broken bead area....that way you get away from the "stressed bead area" and any rusted area...Then lightly roll the bead back into place... I have done several this way with great success....YES it a very big job and very time consuming.BUT it will give you a very strong fender...
Jay's Model A's is offline   Reply With Quote
