05-31-2015, 10:24 PM | #1 |
Tips for Brake Disassembly 1940
I'm in the process of moving a '40 Ford for the first time in over 35 years after sitting outside for much longer than that. Was able to get 3 of 4 wheels to spin, but one of the rears appears to be frozen (car has no engine/transmission installed). In order to get one of the fronts to move, I had to knock the lining off the brake shoes and removed the wheel brake cylinder, but I couldn't remove the two bottom adjuster nuts in order to take the shoes off. I tried holding the bolts from the inside with a pair of vise-grips, only to have them spin when I put an impact wrench on the nuts. Is there a trick to removing the adjusting bolts so that the shoes can be removed?
Alan H. Tast AIA, LEED AP BD+C Technical Director/Past President-Editor-Publications Director, Vintage Thunderbird Club Int'l. (VTCI) http://www.vintagethunderbirdclub.net Author, "Thunderbird 1955-1966" & "Thunderbird 50 Years" 35+ year member, Crown Victoria Ass'n. |
05-31-2015, 11:25 PM | #2 | |
Re: Tips for Brake Disassembly 1940
Bill |
05-31-2015, 11:41 PM | #3 |
May have to torch them off and find replacements
06-03-2015, 10:35 AM | #4 |
