Old 02-01-2015, 10:38 AM   #1
RodRocket
RodRocket's Avatar
Default 37 Ford toe in/toe out setting
Front tires scrubbing on outside edge. Measuring front & back of tires, toe in of 9/16" of toe in found. How does this relate to degrees? I've read conflicting suggestions about whether toe in or toe out is better for handling on straight axle Fords, always discussed in degrees. I don't know of a shop that still does front end work on "old" straight axle Fords, so I am trying adjust the front end myself. Any help is greatly appreciated. Thanks, Rod
RodRocket is offline   Reply With Quote
Old 02-01-2015, 10:53 AM   #2
Cecil/WV
Cecil/WV's Avatar
Default Re: 37 Ford toe in/toe out setting
toe in of 1/16 inch works for me.
Cecil/WV is offline   Reply With Quote
Old 02-01-2015, 11:00 AM   #3
19Fordy
19Fordy's Avatar
The correct toe in is 1/16" as stated above.
Old 02-01-2015, 11:44 AM   #4
Mart
Mart's Avatar
With 9/16" of toe in, I'm not surprised the edges are wearing. Does the tread look "feathered"? (hard to explain what that is if you don't know what I mean. If you brush your hand over the tire thread from outside to inside it will feel smooth. If you brush your hand from inside to outside it will feel less smooth. If it is feathered your hand will pick up on the edges of the tread.
Evidence of feathering will alert an experienced driver that the toe-in may be excessive.
I can't believe anyone would be suggesting toe-out would be suitable for a conventional beam axled vehicle such as an early ford. (4wds may be different, I don't know).
Mart.
Old 02-01-2015, 12:24 PM   #5
JSeery
JSeery's Avatar
Toe out is often used on dirt track race cars with a solid axle. Don't think you would like it much on a street car. Old Fords use toe in and 1/16 as already stated.
Old 02-01-2015, 12:31 PM   #6
ford38v8
ford38v8's Avatar
I'm not even sure you can adjust the toe in that much. Are you sure your method of measuring your toe in is giving you 9/16"? If you're not sure of your method, ask us, as we have several very accurate and easy methods of obtaining that measurement.
Alan
