Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 01-31-2015, 10:31 PM   #1
RodRocket
RodRocket's Avatar
Default 37 ford toe in/toe out setting
Front tires scrubbing on outside edge. Measuring front & back of tires, toe in of 9/16" found. How does this relate to degrees? I've read conflicting suggestions about whether toe in or toe out is better for handling on straight axle Fords, always discussed in degrees. I don't know of a shop that still does front end work on "old" straight axle Fords, so I'm trying adjust the front end myself. Any help is greatly appreciated. Thanks, Rod
Last edited by RodRocket; 02-01-2015 at 10:08 AM. Reason: I shouldn't have mentioned "camber".
RodRocket is offline   Reply With Quote
Old 01-31-2015, 10:52 PM   #2
Lanny
Lanny's Avatar
Default Re: 37 ford camber setting
This section is for "Questions to the the Editor" about this site.
You should post your questions in "General Discussion" in the Early V/8 section here,
and you will get answers from the general membership.....good luck
No one knows what the nose knows,,,Speak Beak
Lanny is offline   Reply With Quote
Old 01-31-2015, 11:15 PM   #3
RodRocket
RodRocket's Avatar
Lanny, love that car! Thanks for the guidance, I'm not new, but new here. Rod
