09-13-2016, 10:32 PM | #1 |
High compression head ?
My friend has a 31 coupe new to him I was helping work on it he thinks it may have a high compression head the only marking on it is the number 10 on top near to the water inlet the numbers are rather big about 3/4 inch high . Does anyone know if this is a high compression head or a stock original ? I never saw one with the number 10 on it ?
Thanks guys b0b |
09-14-2016, 06:34 AM | #2 |
Re: High compression head ?
Probably not. A compression check will show if it is anything over stock which is normally 60-65# PSI.
09-14-2016, 08:20 AM | #3 |
A compression test will answer the question.
Bob Bidonde |
09-14-2016, 11:03 AM | #4 |
I have a 7-1 , compression is about 125#
V4f |
09-14-2016, 12:17 PM | #5 |
09-14-2016, 12:28 PM | #6 |
09-14-2016, 12:53 PM | #7 |
The Snyder high compression heads usually have two round casting marks on the top surface of the head. Each is about the diameter of a dime and they are a few inches apart. They can be located at different places depending on the lot.
Tom Endy |
09-15-2016, 12:11 AM | #8 |
Thanks Guys for your comments . My friend does not have a compression tester he lives about 40 miles from me . I just thought that someone would know what the number 10 means that is on the head . B0B
