Old 05-25-2016, 12:57 AM   #1
Dtolson9
Default Ford model a knock
My 4 banger developed a loud knock today. Can anyone give me pointers on where I should start to fix my problem?
Dtolson9 is offline   Reply With Quote
Old 05-25-2016, 05:41 AM   #2
Utopia Texas
Utopia Texas's Avatar
Default Re: Ford model a knock
Can you give more facts to help determine where the knock is generated? How many miles on the engine? What was going on when the knock started? At idle, acceleration or all the time? Could be a myriad of things from main bearings, rod bearings, wrist pins, piston slap, crankshaft lateral play, crank to cam gear play, cam tensioner spring etc. start by giving some facts and then the group can give you some educated guesses.
Utopia Texas is offline   Reply With Quote
Old 05-25-2016, 09:14 AM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
If you suspect the center main, short out #2 & #3 at the same time & it'll be quiet.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 05-25-2016, 09:17 AM   #4
burner31
burner31's Avatar
Have you checked your oil?
Level/smell/color
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 05-25-2016, 10:37 AM   #5
Dtolson9
Miles of the engine are unknown. The car was sitting there idling and I accelerated a little and the knock started up and is there at idle and acceleration. If you email me I have a video of it running so you can hear what I'm talking about. [email protected]
I have checked the oil and it looks like oil and doesn't have any strange smells and is where it's supposed to be
Old 05-25-2016, 11:29 AM   #6
Tiny
Tiny's Avatar
I sent you an email
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 05-25-2016, 11:33 AM   #7
tbirdtbird
post the vid on youtube
'31 180A
tbirdtbird is offline   Reply With Quote
Old 05-25-2016, 11:36 AM   #8
Tiny
Tiny's Avatar
Disclaimer: I haven't watched them yet just helping out David
Click on the thumbnails for the video
Blackwall Panthers
Nor Cal chapter
Old 05-25-2016, 05:44 PM   #9
Tiny
Tiny's Avatar
I don't what it is but it sounds similar to a friends engine that a wrist pin got loose in and scored the cylinder really bad. Time to pull the head and oil pan and start investigating. I wouldn't be running it anymore until I opened it up
Blackwall Panthers
Nor Cal chapter
Old 05-25-2016, 05:51 PM   #10
Dtolson9
Anyone have any ideas?
Old 05-25-2016, 07:03 PM   #11
700rpm
700rpm's Avatar
It doesn't sound like a main in the videos, at least to me. I'd check wrist pins and rod bearings first, since that is one step to the mains.
Ray Horton, Portland, OR
Old 05-25-2016, 07:09 PM   #12
tbirdtbird
would not load for me
takes me to photobucket then nothing happens, just blank screen
'31 180A
Old 05-25-2016, 08:16 PM   #13
Dtolson9
Anyone think it could possibly be the oil pump?
Old 05-25-2016, 08:28 PM   #14
Brian T
Brian T's Avatar
As it started knocking suddenly after reving the engine, but was OK yesterday I would think it was most likely the timing gear coming apart.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 05-25-2016, 08:39 PM   #15
Dtolson9
In the videos posted there is a video of it running and not knocking and a couple minutes later it started knocking
Old 05-25-2016, 09:11 PM   #16
Tom Wesenberg
Tom Wesenberg's Avatar
The same thing for me.
Old 05-25-2016, 09:12 PM   #17
Dtolson9
This was the first time I have ran the motor for more than 5 minutes since I got and I have no clue how many years it's been sitting
Old 05-25-2016, 09:13 PM   #18
Dtolson9
Email me tom and tbirdtbird and I can send you guys the video. [email protected]
Old 05-25-2016, 09:18 PM   #19
WestCoast
check and see if the crank pulley is loose , it can cause knock like a bad main bearing
WestCoast is offline   Reply With Quote
Old 05-25-2016, 09:36 PM   #20
CT Jack
CT Jack's Avatar
Before pulling the pan try doing the timing gear test. Remove the timing pin on the front of the engine. Find a 1/4" or 3/8" wood dowel approx. 1-1/2" - 2" long. It should be long enough to hold with your fingers. Start the engine and slowly insert the dowel in the timing pin hole until it makes contact with the turning timing gear. Lightly push on the pin and listen to the knock. If the knock goes away or gets softer as you push the dowel your problem is a worn timing gear. This is a fairly simple repair to make.
CT Jack is offline   Reply With Quote
