Old 05-13-2016, 08:20 AM   #1
stegomo
stegomo's Avatar
Default 49T pistons in a 8BA
Can you put 49T pistons in an 8BA engine?
stegomo is offline   Reply With Quote
Old 05-13-2016, 08:32 AM   #2
flatjack9
flatjack9's Avatar
Default Re: 49T pistons in a 8BA
I don't believe I've ever seen 49T pistons.
Old 05-13-2016, 09:27 AM   #3
stegomo
stegomo's Avatar
Pistons from a pre 49 flathead V8
Old 05-13-2016, 02:58 PM   #4
flatheadmurre
flatheadmurre's Avatar
Will a early non offset pistonpin piston fit in a late block...sure...will it perform as it was designed to...no.
Old 05-13-2016, 10:34 PM   #5
stegomo
stegomo's Avatar
So all the aftermarket pistons that fit 39-53 have offset pins?
Old 05-13-2016, 10:57 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
Do your pistons have an orientation mark on the dome?
Old 05-13-2016, 11:17 PM   #7
stegomo
stegomo's Avatar
No there are no marks on them
Old 05-14-2016, 08:49 AM   #8
flatjack9
flatjack9's Avatar
Then they are not offset.
