03-14-2011, 04:34 PM | #1 |
What is the engine RPM's in a 1929 Ford with 21 inch wheels ?
I know I saw on the forum sometime back the engine RPM's at various speeds 30,40,50 Mph in third gear for a 28-29 model A with standard 21 inch wheels BUT I can not find that info now when I need it does anyone have this info ? THANKS B0B in MICHIGAN
03-14-2011, 09:12 PM | #2 |
Re: What is the engine RPM's in a 1929 Ford with 21 inch wheels ?
Bob, here's the formula I have:
RPM=MPH x axle ratio x 336/tire OD Most 21 inch tires have an OD of about 30 inches, and the standard axle ratio is 3.78. eg RPM at 50 MPH=50 x3.78 x 11.2 = 2116.8 |
03-14-2011, 10:57 PM | #3 |
What about 19 inch wheels?
Cowtown A's |
03-14-2011, 11:09 PM | #4 |
03-15-2011, 05:50 AM | #5 |
I always thought the rear end ratio was different for the 19 and 21 wheels. I guess you can learn something everyday.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. |
03-15-2011, 06:59 AM | #6 | |
Fearless |
03-15-2011, 07:29 AM | #7 |
And, many 1928's came with a 3.70 ratio, which is just a hair faster than a 3.78 ratio. 10:37 vs. 9:34 for the ring and pinion
03-15-2011, 07:49 AM | #8 |
I used to keep a business card stuck to the dash rail that I called my "po mans tach". The numbers are approx and were calculated for 19" wheels on my 31 coupe.
400 rpm - 10 mph 600rpm 15 1000 30 1600 45 2000 55 2200 60 2400 to fast |
03-15-2011, 09:05 AM | #9 |
That sounds really low, unless you have an overdrive.
03-16-2011, 01:36 AM | #10 |
The best little book I bought was FORD MODEL A PASSENGER CAR AND MODEL AA TRUCK ENGINE CHASSIS MANUAL. I use the thing for everything including a coffee cup coaster.
It is about 75% of an 8.5 x11 piece of paper. 10 mph=429 rpm 15 mph=643 rpm 55 mph=2357rpm 60 mph=2571rpm 65 mph=2785rpm It says there were two rearend ratio-3.77 and a 4.111 for mountain driving. That is what my favorite book says. It has wiring diagrams and all kinds of good stuff. It is getting in rough shape. I have had it for about ten years.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. Last edited by sturgis 39; 03-16-2011 at 01:46 AM. |
03-16-2011, 10:22 AM | #11 |
That sounds closer to being right. If I can remember, I'll check it on my dream wheel.
03-16-2011, 04:59 PM | #12 |
Here is a little table that I made up.
Speed -mphTire DiameterRear End RatioEngine RPMTire DiameterRear End RatioEngine RPM0293.780303.7805293.78219303.7821210293.78438303.7842415293.78657303.7863520293.78876303.7884725293.781095303.78105930293.781314303.78127135293.781533303.78148240293.781753303.78169445293.781972303.78190650293.782191303.78211855293.782410303.78232960293.782629303.782541Speed -mphTire DiameterRear End RatioEngine RPMTire DiameterRear End RatioEngine RPM0293.540303.5405293.54205303.5419810293.54410303.5439715293.54615303.5459520293.54821303.5479325293.541026303.5499230293.541231303.54119035293.541436303.54138840293.541641303.54158745293.541846303.54178550293.542052303.54198355293.542257303.54218260293.542462303.542380 |
03-16-2011, 04:59 PM | #13 |
Whoops, that didn't work. Looked good for a while.
03-16-2011, 05:14 PM | #14 |
Can't paste an Excel file. Bummer
I give up |
03-17-2011, 02:28 PM | #15 |
Bob
Some of the info on your request is not very accurate. I have mathematicly correct info for the 19 in wheels. ( 19" Wheels with 4.75/5.00/19 tires with 1/2 wear left Rolling distance was 90.75") If for example (and I do not know the distance) the rolling distance for your wheels was 93.5. You would add 3% to the MPH figures assuming you have the 3.78 gear ratio. 65 MPH 2860 RPM 60 =2640 55 =2420 50=2200 45=1980 40=1760 35=1540 30=1320 25=1100 20=880 For RPM TO MPH THEN: 3000=68 2900=66 2800=63.5 2700=61.5 2600=59 2500=57 2400=54.5 2300=52.5 2200=50 2100=47.5 2000=52.5 1900=43 1800=41 1700=38.5 1600=36.5 1500=34 1400=32 1300=27.5 1100=25 1000=22.5
Steve Hanna, Polk City, IA |
