Old 05-29-2016, 12:46 PM   #41
Dtolson9
Default Re: Ford model a knock
I've been told by the local model a guys I can just drop a replacement in since the cylinder isn't scored at all.
Dtolson9 is offline   Reply With Quote
Old 05-29-2016, 01:26 PM   #42
Bob C
The new piston will need to weight the same as the old one.
Bob
Old 05-29-2016, 04:04 PM   #43
Dtolson9
That's what I'm told. I need to measure this one and see what the bore is as well
Old 05-31-2016, 07:40 AM   #44
chap52
chap52's Avatar
Good news that the cylinder was not damaged. Just went through a piston issue with my V8 and went ahead and replaced all the pistons. Figured I would rather do it now while I am still young enough to (70) crawl under the truck. More importantly, get back out from under the truck.
Keep us posted.
Old 06-05-2016, 07:33 PM   #45
Dtolson9
Thanks for the input guys. It's all back together and on the road.
Old 06-06-2016, 07:00 AM   #46
slackcat
slackcat's Avatar
Good to hear.
1929 A Special Coupe
1926 T Speedster
slackcat is offline   Reply With Quote
Old 06-06-2016, 12:54 PM   #47
mshmodela
mshmodela's Avatar
Nice to read... Great job!
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 06-15-2016, 06:26 AM   #48
chrisabes
chrisabes's Avatar
This thread is perfect timing for me with great information. I too have an engine with a bad knock. Pulled it out today to investigate. A couple of members of the local Model A Club have suggested it could be a loose flywheel, as mentioned in a couple of earlier posts. Will know when I pull it apart in the next couple of days.
chrisabes is offline   Reply With Quote
Old 06-15-2016, 06:51 AM   #49
Special Coupe Frank
Special Coupe Frank's Avatar
I'm a little late to the party, but I will chime-in for checking the cam-gear, and the plunger & spring...
My '28 had a knock at idle that sounded very much like a rod-knock... I tried the timing-pin / pressure trick, and it subsided/ disappeared.
Took the side-cover off the timimg area, and let the engine idle: cam gear/shaft was "walking" fore & aft, making a knocking sound. (Do NOT rev the engine with the side-cover removed: your fender will be covered in oil! )
THIS was my "bearing knock"... when I disassembled the front cover, I found the plunger flush at the top of its bore, and the spring in about 3 pieces... it was doing no good.
When I replaced the plunger and spring, and put it all back together, the "rod knock" was gone.
It's an easy thing to check...
Obviously, your case was different ... good thing you shut it down before the cylinder was damaged !
Good luck !
Frank
Special Coupe Frank is offline   Reply With Quote
Old 06-15-2016, 07:06 AM   #50
john in illinois
john in illinois's Avatar
I am late to the party also,but here is good motor noise information. Glad you fixed the piston.
http://www.foxvalleymarc.com/Tech_se...ne_noises.html
John
john in illinois is offline   Reply With Quote
