03-25-2013, 03:20 PM | #61 |
Re: Has anyone every used or heard anything about this thermostat goose neck
Art, take a look at post #9 at the beginning of this thread. The hole you're prepossessing on the left rear of the block connected to the thermostat bypass tube will work just as well as one in the rear of the block. Just make it as low and to the rear as possible.
Ol Jenny, if you have a 6 volt system, use a good Stewart Warner mechanical water temp gauge. Stay away from the cheap mechanical gauges as their temperature response is slow.
AL in NY Last edited by AL in NY; 03-25-2013 at 03:33 PM. |
03-25-2013, 03:24 PM | #62 |
The unit is tapped with both size holes, for either mechanical or electrical style, but comes with plugs. I use the smaller, electrical model, leaving the larger opening available for my hot water heater input.
03-25-2013, 03:26 PM | #63 |
That's what I did. I'm using a 2" Autometer electric gauge.
03-25-2013, 05:11 PM | #64 |
BUT the motometor will rise...have the temp gage and just waiting on the bracket come....thats next!
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
03-26-2013, 10:28 AM | #65 |
AL in NY, or anyone, you advised to stay away from cheap mechanical water temp gauges for the VP Thermostat Housing setup. Are the Deluxe Stewart Warner Mechanical gauges of adequate quality in your opinion? Cost $60 to $75 and look reasonably period. I am really open to suggestions. I am 6 volt and do not have plans for a heater.
03-26-2013, 10:40 AM | #66 |
Along with the benefit, every step away from stock comes with a price, which may include another step. Steve |
03-26-2013, 10:47 AM | #67 |
While on a trip last summer, 400 miles from home, and just for a temporary, I bought a "cheap" ($20) mechanical water temp gauge at O'Riley's. I was able to install it in the 1/2" port on the VP Housing and it worked fine. For my permanent gauge, I have an AutoMeter 12v electric installed in the smaller port, primarily because I intend to install a heater in the larger port.
03-26-2013, 10:48 AM | #68 |
OL Jenny, the SW Deluxe mechanical gauge is the one I used and it works beautifully and very actuate, I highly recommend it.
AL in NY |
03-26-2013, 01:53 PM | #69 |
Thanks to everyone for the advice. I had a wonderful conversation with Vintage Precision about their thermostat housing. Great people--- VP Housing on the way, as well as a SW Deluxe Mechanical Water Temp gauge. Waiting for a rebuilt Zenith to arrive from Bert's, bring on the touring season.
03-27-2013, 10:30 AM | #70 |
This is the gauge I am using...or will use when I install it..
03-27-2013, 12:56 PM | #71 |
That is the gauge I am using; it works well.
It is also very accurate as I have checked it with my IR laser temperature "gun" pointed at that location on the housing. |
03-27-2013, 01:04 PM | #72 |
Yea used in my tudor BUT Cant find a SINGLE gauge holder for the steering column for it ONLY the Instrument panel.....any suggestions.???
03-27-2013, 01:39 PM | #73 |
'Sorry, but I have no suggestions; I mounted it under my instrument panel with the plain-n-simple supplier gauge holder.
03-27-2013, 01:43 PM | #74 |
Mark, try this link for steering column mount gauge cups:
http://www.jegs.com/p/Auto-Meter/Aut...45207/10002/-1
AL in NY Last edited by AL in NY; 03-27-2013 at 01:52 PM. |
03-27-2013, 01:49 PM | #75 |
Berts has a single gauge steering column mount:
Single Gauge Bracket- Mounts To Steering Column- 2 1/16"- Polished Aluminum- USA Made
03-27-2013, 02:07 PM | #76 |
Thank you....60.00 BUCKAROOS!!!!!+ shipping...yikes....
03-27-2013, 03:59 PM | #77 |
But Mark! It's really really pretty. (I have the 2-holer and with a little modification to fit my needs, it's just perfect!)
03-27-2013, 03:59 PM | #78 | |
Well what the hell RIGHT...Pretty counts for everything.....
03-27-2013, 04:55 PM | #79 |
On kinda a side note, when I was installing my engine I put a mechanical temp gauge sending unit in the lower pipe return because I didn't like the unsightly installation up top. I know that it’s seeing the cooled water coming from the radiator but it still gives me the point of reference. During the summer here in Florida it runs about 160 or so. The sender is on the underside placed in a welded bung. I then route the sender tube up with the Genny harness to the terminal box.
Wanted: Simmons Super Power Head Craig Likon 1931 150B |
04-10-2013, 11:31 PM | #80 |
Here's the "thermostat" that I use to warm the car. Works great, and never fails.
It takes about 5-6 minutes for the car to warm to the 160 degree mark on the motometer. When it hits the mark I want, I simply lift the "thermostat" off the radiator and put it back in the garage for next time. Then, drive the car. I imagine that Mark or Tom will have something to say... |
