12-20-2012, 01:11 PM | #81 | |
Re: Hydraulic brakes questions - super hard pedal
You are not out of the woods yet. The 16 inch wire wheels you have are probably from a '35 as the '34 wheels were 17 inch. Hard to tell for sure without a picture. The Ford wire wheels through '35 all needed the adapter. Attached you wil find photos of the original Model A drum and hub assembly with an arrow pointing to the raised ring. This was replaced with raised and machined areas in the drums beginning with the late '31 cast drums and going through '35. The '40 drum did not have this raised area and needed an adapter ring as shown. |
12-20-2012, 01:21 PM | #82 | |
Charlie Stephens |
12-20-2012, 01:45 PM | #83 |
I'm sure the adapters would not hurt - where do you buy them? If I go back to 19 - 21" rims I would defiantly need them
12-20-2012, 02:38 PM | #84 | |
Charlie Stephens |
12-20-2012, 09:29 PM | #85 |
Car has had 16" wheels on it for seven years - why not 19"? This is by no mean an original show car.
12-21-2012, 11:10 AM | #86 | |
Charlie Stephens |
12-21-2012, 11:56 AM | #87 |
I'm not sure I need the spacers with the 16" wheels as they are from a 34-36 era car and with juice brakes my hubs are 39-46 they seem to pull down all they way - am I missing something here?
I understand if I put 19 -21 inch like what was on original I would need the spacers with the hubs I have - right? |
12-21-2012, 01:21 PM | #88 |
All of the 1928-35 wire wheels had a step to allow or the ring or machined pads. I don't know the reason for this step but the engineers obviously intended that there be support in this area. I tend to error on the safe side and use the adapters. As someone else pointed out with the low mileage and gentle usage you can probably run without the spacers for years. Look at the back of your wheels and you will see where this step is, put some modeling clay there and you will see there is a gap. If I had a limited budget I would put the brake clips or hub retainers on first.
Charlie Stephens Last edited by Charlie Stephens; 12-22-2012 at 04:12 PM. |
12-31-2012, 12:03 PM | #89 |
Anyone had luck using a wheel puller like this found on ebay?
12-31-2012, 05:24 PM | #90 |
I've noticed in post#47 that the brake shoe installation is inconsistent front and rear. Question: does the long lining shoe fit into the large end of the wheel cylinder and the short lining shoe fit into the small end of the wheel cylinder?
01-01-2013, 09:27 AM | #91 |
Maybe I should pull both rears again and compare as the right rear is okay but I have too much drag in the left rear and can't adjust it to be free. Its not real bad but more than I would desire and it seems the shoes do not retract all the way. If I snap the ebrake cable sometimes its better, then I step on the brake and it drags again, so among other things it appears to be sticking. I bought one of these hub pullers on eBay so until it comes I can't do anything. The first time I took it apart the hubs came right off only because the axle nut was not tight at all.
01-01-2013, 01:58 PM | #92 | |
Charlie Stephens |
01-01-2013, 03:18 PM | #93 |
The E-brake cable should be backed off a long way so that brake shoe-to-drum clearance can be correctly adjusted. Once this is accomplished, adjust the E-brake cable. Also check for cable freedom of movement: it must retract completely on its own without assisted "snapping" or jiggling.
01-16-2013, 02:12 PM | #94 |
I bought one of those wheel pullers posted in #89 - it worked very well
