05-02-2012, 01:57 PM | #1 |
Bolt Tap Sizes
Where can I find a chart for tap sizes of each bolt on the Model A and more important the pitch for each of these? Also how would I know I've got the correct pitch tap? Is it marked on the taps?
thanks for your time. Joe Grobleski Cape Codder |
05-02-2012, 02:31 PM | #2 |
Re: Bolt Tap Sizes
Taps and dies are marked as to size etc. there was a listing of some bolts in the Restorer Mar/Apr 2000. alot are S.A.E.,U.S.F., NF etc. I'm sure there are other lists available.
www.whidbeymodelaclub.com |
05-02-2012, 02:52 PM | #3 |
Re: Bolt Tap Sizes
You need to get the correct class of fit:
Classes of fit The way in which male and female fit together, including play and friction, is classified (categorized) in thread standards. Achieving a certain class of fit requires the ability to work within tolerance ranges for dimension (size) and surface finish. Defining and achieving classes of fit are important for interchangeability. Classes include 1, 2, 3 (loose to tight); A (external) and B (internal); and various systems such as H and D limits. Ford made many of the threads to a tighter tolerance. A quick example are the rods that go from the radiator to the firewall. I made the mistake of taping these and found the nuts to be VERY loose. Many of the nuts and bolts on the A will pull a small amount of metal out and they get much looser. Anymore I hand clean the threads of nuts with a pick and wire brush the bolts. OH- some nuts are super hard and can ruin taps. |
05-02-2012, 03:04 PM | #4 |
Re: Bolt Tap Sizes
Here's a list of standard stuff.
http://www.shender4.com/thread_chart.htm You will have to go to the Ford engineering drawings for sizes peculiar to model A's only. MAFCA had a list some time ago. |
05-02-2012, 03:22 PM | #5 | |
Re: Bolt Tap Sizes
05-02-2012, 03:37 PM | #6 |
Re: Bolt Tap Sizes
05-02-2012, 03:51 PM | #7 |
Re: Bolt Tap Sizes
Please save yourself a heap of headaches, bite the bullet on the price and purchase a thread chaser kit. They are way different from a tap and die set. They will clean threads without removing metal and will save you a lot of misery. Mine is a Craftsman 40 piece Rethreading Kit. Had it so long I can't remember what I paid for it but it was well worth it. Saved many a thread on my Tudor!
Paul
I have nothing against mankind. It's the people in it that I can't stand. |
Thread Tools | |
Display Modes | |
