04-15-2012, 07:21 PM | #1 |
Commercial Running Boards
Would be interested in methods others have come up with to protect the paint (top side) on commercial running boards (i.e. no rubber matting) from shoe scuffs during day-to-day use. I don’t have the heart to drill holes in originals to install the aftermarket metal step plates. Ideally, something that is easily removable for instances where one might wish to ‘show’ the vehicle. Have thought about heavy canvas or carpet remnant (nap down to paint surface) with magnets sewn at the corners, but thought I’d try the ‘Barn’ before making such a venture.
04-15-2012, 07:23 PM | #2 |
Re: Commercial Running Boards
I did put step plates on my pickup but found out that with my long legs, I just don't step on the plates or the running boards.
04-15-2012, 07:30 PM | #3 |
Well, for me I usually recommend to customers that they enter the Model-A without even stepping on the board. I too find it easier but some may be limited in that regard. On my Model-Ts, I actually powdercoat the board in Black first and then scuff the powderpaint with a gray Scotchbrite and then apply one slick coat of PPG single stage Black over the top of the powderpaint. Generally speaking, as long as you step directly on the running board and not twist your shoe, it will last for years with no evidence of degradation. Since you can paint yourself, then when they start driving that truck, just pull them off from time to time and re-shoot them.
04-15-2012, 10:09 PM | #4 |
Step over the running board.I don't use them on my tudor. Learned how to do this back in the 60's when my 32 5 window had WHITE running boards (no mats). It's an easy habit to get into.
Paul in CT |
04-16-2012, 07:10 PM | #5 |
yes,i think that Brents idea of powdercoating/scuffing with grey scotchbrite/then your chosen black finish is a good idea.if you wear thru the paint,you have the very durable powdercoat underneath.i personally think the wearing down of paint on the raised areas gives it patia.
04-17-2012, 06:40 AM | #6 |
04-17-2012, 08:57 AM | #7 |
Then do as they did in the day and enter from the curbside!!
