07-08-2010, 12:16 PM | #61 |
Re: Can you run an A wide open?
Heat conductivity is the same on a thin piece of babbitt, as it is on a thick wall piece of babbitt. A thick, or thin piece of brass will get hot fast when you grind on it, the thick one just takes a minute longer. Now the place where you loose heat transfer is where the babbitt meets the bearing shell. Cast iron has to be CORRECTLY peened, and steel CORRECTLY tinned, BUT the babbitt has to be stuck to the tinning, in which many places putting out bearings, are not. The OIL behind the bearing is what cuts down heat transfer, as OIL is not a good conductor, not the thickness of the babbitt, or the thickness of the shell. you need babbitt metal, to shell metal contact ((( 100%))), on a tinned, or peened bearing, or it will fail before its time. Just because you tin a bearing shell, that does NOT mean it stuck, when it cooled. If it didn't, the babbitt will push in, and out to the shell, and bust up, that also goes for cast iron pouring. feed back anyone, thanks Herm
07-08-2010, 12:54 PM | #62 |
Balancing was specified on the crank print and heavily touted in the book "Know Your Model A Ford" and in the dealer sales literature recent published in the 'Restorer'.
I do not have the crank print handy, but I believe 1/4oz dynamically was the limit. The rod print specs a specific weight +-1 gram on each end. I have heard the pistons were supposed to be done down to a few grams each, but I do not have documentation. The flywheel was balanced, but I am not 100% if it was done dynamically. One other tid bit. I was reading something where they were explaining the machine that balanced the cranks and how accurate the machine could be. It could balance the crank better than Fords spec. An interesting aside. My brother was taking down a flywheel and found a fairly large void in the casting. Opposite the void was a fairly large balance hole drilled into the edge. |
07-08-2010, 01:26 PM | #63 |
Originally Posted by George Miller
Re: Can you run an A wide open? Quote: Originally Posted by George Miller If you ran a new car for long periods of time wide open it would not last. Of course I know all that. My point is you can not run any engine wide open for long periods of time. Tom I would have to see that to believe it. just because it is written does not make it true. If engine could run wide open for ever, how come NASCAR engines have to be rebuilt after ever race. |
07-08-2010, 02:09 PM | #64 |
i ran mine out yesterday . about 75 mph , but its the first & only time ill do it . not comfortable for me or my car at that speed ................ me & my car love 55-60 mph . ....... steve
V4f |
07-08-2010, 02:17 PM | #65 |
Herm , I'm not a babbitt guy, never did it.. But, I've installed my share of inserts and one of my pet peeves is to watch someone dunk the shell/insert into a puddle of oil and stick it in the block/rod/cap..That drives me nutz.. Regardless, a bearing is a bearing isn't it..
07-08-2010, 02:52 PM | #66 | |
07-08-2010, 03:31 PM | #67 | |
07-08-2010, 03:50 PM | #68 |
Kohnke Rebabbitting. I may have missed it if you said it but, In your opinion is it fine to run the A engine wide open at 2800-3K rpms or not?
I assume it will shorten the engines life (as with ANY engine) but I doubt it would do any real harm assuming everything is in proper working order? In regards to sudden RPM changes damaging engines, We used to have a family friend who loved to rev his engines constantly. He felt it impressed people. At any rate, on one of engines the timing chain jumped a tooth with only 30,000 miles on it. It was always assumed the extreme wear on the chain was from him constantly reving the engine, forcing it to suddenly speed up and slow down the cam. This was on a 1960s chevy smallblock (327 I think) my dad had built for him. |
07-08-2010, 04:14 PM | #69 |
50,000 miles on a Model A is like 150,000 miles, maybe 200,000 miles, on a car today. I drive with my foot on the floor most of the time because its more fun and I'm sure that's how the kids drove their parents' Model A.
07-08-2010, 05:05 PM | #70 | |
Sorry Jack ..... or is it Gomer? .... I mean Herm.... I disagree with your view on thick babbitt. Also, that 42 year comment doesn't necessarily impress anybody. On the other hand, if your knowledge of babbitt bearings has been increasing DAILY for 42 years then you must be a smart s.o.b........ More than likely though you learned most of what you know in about 5 years or so ... so that means you have only 5 years experience 8.4 TIMES OVER! In my opinion, the thinner the babbitt the stronger. Now depending on the differences it may not be greatly significant in all cases or even be a problem but it's still there. If an undersized crank is off center a bit too much or slightly distorted in its operation for one reason or another; like so many of them are; the crank will tend to beat and compress the thicker soft babbitt more than the thinner by comparison and create excessive clearance possibly leading to bearing failure. Of course if a bearing fails you can bet that it won't be the fault of the engine rebuilder! Just my experience ..... stated in the same manner as you. Larry B. Last edited by Larry Brumfield; 07-08-2010 at 06:03 PM. Reason: spelling |
07-08-2010, 05:21 PM | #71 |
Man, this is awesome. Not only did a thread I start gain so much popularity, zig-zag a bit off topic, AND get some great opinions about running an A wide open, but there are little verbal scuffles going on in here as well! Who could ask for anything more. All we need now is some virtual beer. Thanks guys!
07-08-2010, 05:41 PM | #72 | |
The only opinion I have on thick babbit is, obviously there were things considered in designing the engine and they for SOME odd reason picked the original thickness and I would have to assume deviating from this thickness in any direction could and most likely would cause problems. Again, this is just going on my usual assumption that all things are done for a reason (and they usually are). Last edited by MrTube; 07-08-2010 at 05:46 PM. |
07-08-2010, 06:03 PM | #73 |
"In my opinion, the thinner the babbitt the stronger and the thicker the softer. Now depending on the differences it may not be greatly significant in all cases or even be a problem but it's still there." (Larry Brumfield)
I just happened across this thread so I guess I missed most of the fun. Larry is right according to the laws of physics..That is one reason modern shell bearings only have babbit .0002 thick. Actually a given bearing material will deflect at the same RATE for different thicknesses but the thicker one will deflect farther with the same load thus causing more movement in the total assembly..This movement caused by the reciprocating forces equates to less bearing life. The bearings in a model A engine are so lightly loaded that almost any thickness would work though. |
07-08-2010, 08:39 PM | #74 | |
Hi Herm, You were looking in the wrong place based on modern methods. Note the circumferential grind marks on the edges of both ends of the connecting rod. This was the last stage and when you study original rods you will find no two identical. The amount of "meat" removed is based on the particular weight removal requirements. I'd love to see the original machine. The machine certainly must have been automatic like the piston balancing machine which weighed the shavings and quit when the shavings weighed the same amount as the determined excessive weight. At the beginning of production Ford balanced connecting rods in sets of four. They made it very clear to the dealers that they MUST replace connecting rods in complete sets to maintain the proper balance. Ford worked out their production / balancing methods and began making ALL connecting rods the same weight beginning April 24, 1928. They began providing the same for service May 10, 1928.
http://www.abarnyard.com/ |
07-08-2010, 09:00 PM | #75 |
Here are the crank specs off the drawing.
07-08-2010, 10:12 PM | #76 |
Herm, I think that the method used to balance the rods is the machining on the outside of both the big end, and the small end, they all seem to be very close to the same at the edge, but the depth, and the angle is somewhat different, with the thicker forgings having more machining ---the same method was carried over to the V8 flathead rods.
The Ford blueprint shows a weight spec of 198 grams +-1 for the small end, and 512 +- 1 for the big end. I had a boxed NOS set of B rods, they weighed out within 1/2 gram of each other at both ends. The crankshaft print has a balance spec--"shaft must be in balance dynamically within 3oz inch at any 1 point of reference, shaft must be in balance statically within 3 oz inch" |
07-08-2010, 10:50 PM | #77 |
Comparing rods
Here are two rods from the same engine. Notice the difference in the amount of material that has been removed at each end.
Bob |
07-08-2010, 11:39 PM | #78 | |
07-09-2010, 12:02 AM | #79 | |
07-09-2010, 12:53 AM | #80 | |
