Old 08-29-2011, 08:55 AM   #1
donQ
Default fan belt installation
Is there an easy way to install the fan belt? I rebuilt a generator and installed it on my 29. I purchased a new cogged belt from NAPA (5/8 x 43 PN 25-20426). The generator mount bolt was loosened and the generator rotated in until it touched the block. The belt was slipped over the crank and fan pulleys and then I attempted to work it on to the generator pulley. I was finally able to get the belt on but I was concerned that I'd have to ruin the belt to force it on. Is there some easy way of doing this?
donQ is offline   Reply With Quote
Old 08-29-2011, 09:04 AM   #2
Steve Plucker
Default Re: fan belt installation
Maybe you got a smaller belt then normally used...it should of not been that hard to do!
Pluck
Old 08-29-2011, 09:05 AM   #3
Ned
I use a 44" belt, generic part number is 5L440. Most auto parts places carry them. Easy to install even wiht a power house generator.
Ned is offline   Reply With Quote
Old 08-29-2011, 12:01 PM   #4
Ron Lowe
The pulley on the generator is on a tapered shaft. Take the bolt out that holds the pulley on and it will come off easy. Now you can put the belt on the pulley and then onto the shaft. Should be alot easier this way. Good luck Ron
Ron Lowe is offline   Reply With Quote
Old 08-29-2011, 06:52 PM   #5
donQ
Thanks for the suggestions. I think Ron's idea to remove the pulley is a good one. I'll check into the longer belt for a spare to carry along the road.
Don
Old 08-30-2011, 09:53 PM   #6
Ned
I have seen the pulley get stuck on the tapered shaft and would be hard to remove with the generator mounted on the engine. You can loosen the nut, hold the generator up by the pulley and tap the end of the shaft. It will normaly break free.
Old 08-30-2011, 10:08 PM   #7
Milton
Milton's Avatar
I used to do this by putting the belt on the crank and generator pulleys and then start the belt on the fan pulley and pull on a fan blade to rotate the belt on.
Milton is offline   Reply With Quote
Old 08-30-2011, 10:16 PM   #8
james hitchcock
james hitchcock's Avatar
Really sounds like the belt is just too small. Never had any trouble .
james hitchcock is offline   Reply With Quote
Old 08-30-2011, 10:25 PM   #9
Fred K-OR
Fred K-OR's Avatar
Ron's way is the only way I found to get my belt on. Mine is a current aftermarket belt that is suppose to be for an A but they don't fit well.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 08-30-2011, 11:49 PM   #10
Steve Plucker
Just get a larger belt then the one you have...that way you will not have to take things apart! Just losen up the generator, slip the belt on, then adjust the generator to the proper belt tension...Plain and simple.
Pluck
Old 08-31-2011, 07:21 AM   #11
Glen in Hillman MI
I use a NAPA-B41, it fits well and last for miles. [15,000 PLUS]
Glen
Glen in Hillman MI is offline   Reply With Quote
Old 08-31-2011, 06:54 PM   #12
Larry Seemann
I use the NAPA B41 also. Taking the generator off, fitting the belt in the pulley, and reinstalling the generator also works.
Larry Seemann
Larry Seemann is offline   Reply With Quote
Old 08-31-2011, 06:59 PM   #13
Elcastor
Elcastor's Avatar
I agree with those that said just get the next size longer belt. I have never had the problem you are experiencing.
Ben Purkey
Mexico and the Pacific NW
http://www.martin-parry.com/
Elcastor is offline   Reply With Quote
Old 08-31-2011, 07:08 PM   #14
reek29
reek29's Avatar
The 25-20426 belt is one that I went to when I installed an alternator. The alternator pulley is significantly smaller in diameter than the generator pulley, and I had problems with the belt being loose with a standard lenth belt. I think the others are right when they suggest going to a normal size belt, available from any of the parts vendors. Good luck.
reek29 is offline   Reply With Quote
