08-22-2017, 06:56 PM | #21 |
Re: Starter slows then stops
I wish people would read the entire thread before responding so we wouldn't get the same suggestion repeated over and over again.
08-23-2017, 07:54 AM | #22 |
I read a few, then I give my advice. I don't read all because of time. I can't read as fast as I used to. Giving the same suggestion over and over reinforces it. unless it's wrong, that's a good thing. Sometimes I read solutions that are totally of the wall, probably because the responder didn't fully understand the problem being presented. I come back a re read what I wrote the next day and see my mistakes. Sometimes I cringe! But when you have a problem, don't you feel better about it when everyone agrees on the solution?
Terry |
08-23-2017, 08:53 AM | #23 |
Update:
Charged the battery and boy does the starter sound good!!! Cleaned all the connections, "clean-bright and tight". Now, motor will not start. I have cleaned the sparkplugs and one plug's ceramic spins. Guess it's time for new plugs. One thing at a time and I will get her running again. Question: To retard the spark do you pull the left lever all the way down or push it all the way up? Previous owner said to pull it all the way down and it has started in the past. I am just making sure all my ducks are in a row. Thanks again all. |
08-23-2017, 09:09 AM | #24 | |
I say this because it happened to me. I went back to the guy I bought the car from and he said the same thing. 1) make sure the key is in the ignition and turned on; (2) Make sure to turn the gas valve back on; (3) Make sure to start with lever fully retarded. Retarded is all the way up on the lever Two levers to deal with : Gas valve - open is when valve handle is 100% vertical (up and down) Located under the gas tank inside the car on most cars just over the passenger's feet and against the firewall. Later models were located outside under the hood on the firewall. Second is the spark advance. It is the lever on the left of the steering column where you would expect to see a turn signal on a modern car. Retarded is all the way up, which is where you want it for starting. Lower down for best running once the engine starts. Last edited by Magicbox51; 08-23-2017 at 09:15 AM. |
08-23-2017, 09:16 AM | #25 |
The larger battery post is the positive post. A long slow charge is much better for the battery than a fast high amp charge.
Also, before cranking the engine, make sure the spark lever is full UP, so you aren't cranking with an advanced spark, as that will kick back against the starter, and may bend the Bendix spring, or break the Bendix. |
08-23-2017, 03:24 PM | #26 |
Terry |
08-23-2017, 07:16 PM | #27 |
UPDATE.....
1. Charged the battery (it was low). 2. Clean, Bright and Tight all connections.... 3. New plugs 4. Installed battery.....turned the key....one pull on the choke.....FIRED RIGHT UP!!! THANKS to everyone who led me down the right path. I am new to this vehicle and can see she will be fun. |
08-23-2017, 07:28 PM | #28 |
Congrats on getting it going!
I checked out your photo album. Looks like a fun truck! Hope you and the Model A have many happy adventures together.. Jeff
Let's let pylons, be pylons! |
08-23-2017, 08:01 PM | #29 |
Thanks Jeff (JDupuis)....
08-23-2017, 08:18 PM | #30 |
I think most if the fun of having a Model A is dealing with the issues.
08-23-2017, 08:44 PM | #31 |
You didn't harm the motor by reversing the connections. This is a DC motor and when you reversed the connections you reversed the rotation of the starter which prevented the bendix from engaging with the ring gear.
I would rebuild the motor and as thread #20 indicates use extra havey gauge cables. This will minimize electrical resistance between the battery and motor and allows the starter motor to operate at peak power. Make sure you have a good battery and the starter switch is in good working order. Remove any pitted areas from the switch contact surface on the motor. |
