Old 02-14-2018, 11:19 PM   #41
Simonpie
Default Re: Rear Panhard Bar ?
Originally Posted by pooch View Post
As long as you realise a panhard bar cures wallowing , NOT roll as has been suggested here.
A sway bar is for roll.
I'm going to disagree on this one. The roll center on a torque tube rear end runs at the height of the universal joint. The roll center with a Panhard bar is where a line directly up from the axle crosses a line from the center of the u-joint to the center of the Panhard bar. Basically, this is right at the height of the Panhard bar, a good 6 inches above the u-joint. The closer the roll center is the the CG, the lower the roll. 6 inches is a pretty good improvement.
Simonpie is offline   Reply With Quote
Old 02-14-2018, 11:32 PM   #42
Purdy Swoft
Purdy Swoft's Avatar
The backend can rock side to side on the rear spring shackles . The panhard bar holds the rear axle steady on sharp turns
Old 02-15-2018, 12:35 AM   #43
pooch
pooch's Avatar
Not really, more like the body/chassis/spring can rock side to side on the backend.
pooch is offline   Reply With Quote
Old 02-15-2018, 01:35 AM   #44
updraught
updraught's Avatar
" ... The roll center on a torque tube rear end runs at the height of the universal joint."
That's up near the gearbox and chassis rail.
"The roll center with a Panhard bar is where a line directly up from the axle crosses a line from the center of the u-joint to the center of the Panhard bar. Basically, this is right at the height of the Panhard bar, a good 6 inches above the u-joint. The closer the roll center is the the CG, the lower the roll. 6 inches is a pretty good improvement."
That's half way between the diff and chassis rail?
The center of gravity will be higher for a sedan than say a speedster.
updraught is offline   Reply With Quote
Old 02-15-2018, 02:25 PM   #45
Simonpie
You're right. That 6 inch estimate may be quite a way off. I may need to crawl underneath and look around.
Old 02-15-2018, 02:58 PM   #46
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by Synchro909 View Post
Does anybody have a picture they can post of a panhard bar installed please?
Synchro, I gave it my best 'shot'. Hard to get a good picture as it is above the rear axle. This picture is looking toward the rear of my car.
Old 02-15-2018, 02:59 PM   #47
hardtimes
hardtimes's Avatar
Hey Simon,
Thanks for sharing drawing !
Is there a set distance/location on the right frame rail where the bar attachment is shown ? Or, can it be randomly placed in the general vicinity shown In drawing ? Is the length of bar set, as made and sold by vendors,
or is a longer bar better ??
hardtimes is offline   Reply With Quote
Old 02-15-2018, 03:01 PM   #48
hardtimes
hardtimes's Avatar
What picture ?
Old 02-15-2018, 03:08 PM   #49
Y-Blockhead
Originally Posted by hardtimes View Post
What picture ?
Can't see it? I see it... I can even see it in your post. If you can't see it go to my picture album.
https://www.fordbarn.com/forum/album.php?albumid=3320
https://www.fordbarn.com/forum/pictu...ictureid=39757
Hardtimes, that drawing is Bass Ackwards. The Panhard bar available form the vendors mounts to the LR shock mount and the center section of the rear axle.
Old 02-15-2018, 03:14 PM   #50
Y-Blockhead
Picture where it mounts to left rear shock.
And center section.
Old 02-15-2018, 04:43 PM   #51
pooch
pooch's Avatar
Dunno about the aftermarket Model A panhard bars, but as to a general bar, the longer the betterr so to minimise arc length change movement.
And the bar should be up hill to chassis a bit ( in height elevation) at normal riding height loaded, so its working life going over bumps is in the best arc.
Old 02-15-2018, 04:56 PM   #52
Synchro909
Synchro909's Avatar
Thanks for your efforts, Y Blockhead but I can't get to see anything on the album either - never have on this forum. Don't know whether it's something I should do here or something should be done behind the scenes.
Does anybody else either have a picture or have a suggestion as to how Y might be able to load the pictures?
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 02-15-2018, 06:39 PM   #53
updraught
updraught's Avatar
[QUOTE=Y-Blockhead;1593356]Can't see it? I see it... I can even see it in your post. If you can't see it go to my picture album.
The first link gives:
"Invalid Album specified. If you followed a valid link, please notify the administrator"
The second is blank.
In your public profile there is only statistics and contact info. Nothing else.
Other users I checked look OK.
Maybe check your "profile privacy"?
Old 02-15-2018, 07:12 PM   #54
pooch
pooch's Avatar
Same here, Y Blockheads album and pic are dead to me too.
Maybe it is this new server Ryan has, has stuffed things up?
Old 02-15-2018, 07:14 PM   #55
Y-Blockhead
Well sorry guys. I never had this problem before. Maybe it has something to do with the Ford Barn server upgrade?
Sooo, let us try Flickr... Please let me know if this works. I can see all the other pictures I posted just fine.
Old 02-15-2018, 07:17 PM   #56
SSsssteamer
SSsssteamer's Avatar
I followed this Panhard post from the beginning. Having driven our 1929 Tudor for 50 years, at 45+ mph on the country roads, the Tudor can be a real challenge to keep it on our side of the road. It always dips and dives all over the place. It has all new spring shackles, shock absorbers and the tudor is in great shape. I ordered the Panhard from Snyders (on line) on Sunday and I received it on Wednesday by USPS. Cost plus shipping came to about $150. It took about 30 minutes to install and then I test drove our Tudor. I just got back from driving on the same country roads. The Tudor showed about a 90% improvement on the dipping and diving. Body roll was greatly reduced too. It was money well spent.
SSsssteamer is offline   Reply With Quote
Old 02-15-2018, 07:28 PM   #57
updraught
updraught's Avatar
Pictures are coming thru load and clear Houston.
Old 02-15-2018, 07:38 PM   #58
Y-Blockhead
Not sure how clear but...
This one shows how it is mounted to the LR Shock
and this one shows the rear axle center section
r
Sorry they are not clearer, hard to take pictures laying on my back...
Old 02-15-2018, 09:20 PM   #59
pooch
pooch's Avatar
So it is only a half panhard bar.
Not as good as a long one but better than nothing.
I sometimes wondered if the side it was anchored to chassis mattered re RHD and LHD cars. .
The RHD OZ car I copied mine from was anchored on left as well.
Old 02-15-2018, 09:39 PM   #60
Synchro909
Synchro909's Avatar
Thanks for the pics - clear enough for me.
