Old 04-24-2017, 03:12 PM   #81
Art Newland
Art Newland's Avatar
Default Re: Taking a break for some brakes.
No probleemo, It will be interesting to see how these work compared to Dick's with FHT's floaters. I might go that way yet... we'll see. I have lower back troubles so about an hour and a half of this brake stuff is all I can do. Seems funny that all I accomplished today was turning a bolt two turns...
Art Newland is offline   Reply With Quote
Old 04-24-2017, 03:20 PM   #82
RawhideKid
Just think about that bolt and what it took to get those 2 turns!
I say Well Done!
You know, that bolt is still going to be there tomorrow, and maybe just as stubborn as it was today, so save your energy and give it another blast tomorrow.
RawhideKid is offline   Reply With Quote
Old 04-24-2017, 04:35 PM   #83
Art Newland
Was thinking about removing the muffler and brake cross shaft so I could get a better swing at the bolt... then it moved! Made my day.
Old 04-24-2017, 06:40 PM   #84
updraught
updraught's Avatar
Originally Posted by Y-Blockhead View Post
Flathead Ted's kit works great but it is designed to be added to a good working stock braking system.
In Ted's youtube video he uses a small grinder to flatten the track. Not sure I'd do that. Depends how munged the track is I guess.
updraught is offline   Reply With Quote
Old 04-26-2017, 11:23 AM   #85
Art Newland
The offending bolt is removed! The rear backing plate bolts looked pretty worn so I've ordered new ones, along with the radius rod bolt. I added a impact wrench to my tool chest, I don't have room for a large air compressor so I opted for the Ryobi cordless one. I have other Ryobi tools so I already had batteries. I could hardly turn this bolt with a 1/2 inch breaker bar, and this turned it no problem at all, would have saved me hours and many Advil.
Old 04-26-2017, 12:26 PM   #86
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Tools
One of the best reasons for owning a Model A is it is a good excuse to buy more tools.
Old 04-26-2017, 01:20 PM   #87
CarlG
CarlG's Avatar
Default Re: Tools
My thoughts exactly
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 04-26-2017, 05:43 PM   #88
denniskliesen
denniskliesen's Avatar
Default Re: Tools
Originally Posted by CarlG View Post
My thoughts exactly
Not only more tools, but proper tools... can't adjust brakes with a crescent wrench gotta have the special square hole wrench the vendors sell.
denniskliesen is offline   Reply With Quote
Old 04-26-2017, 06:49 PM   #89
Art Newland
No wonder so many people build more than one A. You've already got all the tools... might as well!
Old 04-26-2017, 07:01 PM   #90
Jeff/Illinois
Jeff/Illinois's Avatar
The front assemblies were about 25 lbs, and the rears about 35. I'm expecting my brakes back sometime this week. Randy sent me a couple picture to wet my appetite. My brakes were a real hodge-podge of incorrect parts, aftermarket pieces, stuff missing, and just worn out stuff. Surprisingly, for getting around my repetitively flat surroundings, they worked OK and I never really felt unsafe driving. Randy has a good selection of good used parts on hand and hooked me up with a good front hub (loose bearing race) and a replacement emergency brake ass'y, one of mine was cracked. I've really enjoyed being kept "in the loop" on the process. He's called me several times with updates, questions, and concerns... I really like that.
Wow!! Impressively good work.
Jeff/Illinois is offline   Reply With Quote
Old 04-26-2017, 07:03 PM   #91
Jeff/Illinois
Even with Randy's really good packaging, They still managed to bend one of the backing plates... how frustrating. After spending nearly $280 in shipping costs, it's really disappointing. Another reason I'm not excited about shipping an engine off to be rebuilt.
Art that seems to be the norm today
Old 05-01-2017, 02:10 PM   #92
Art Newland
The Saga continues...
I ordered new bolts for the rear backing plates while ordering the radius rod bolt. Also ordered new clevis' , from Berts because they ship fast. The clevis' were out of stock, did they warn me of that fact... no. Shipped the rest anyway. And the bolts are awful. The radius rod bolt is nearly chrome! Not a show car, so what. But the backing plate bolts are bad. One of the short ones is even a different thread, none of the long bolts threads are cleaned up after drilling for cotter. Its all going back. As my coupe sits there on the jack stands.
Old 05-01-2017, 03:01 PM   #93
Dick Steinkamp
Dick Steinkamp's Avatar
Art,
I have a whole box full of hardware that I purchased from various reputable vendors. All were worse than reusing my old. Most were not even close to looking like the originals. I finally learned. Unfortunately the backing plate bolts are not standard. Hopefully you can find some good used ones.
Hardware Sales should have the radius rod bolt.
I found my clevises were still within specs. The clevis pins...not so much. Hopefully that's all you need and hopefully they are available.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 05-01-2017, 03:10 PM   #94
Art Newland
The short bolts on the rears won't tighten all the way. Can only assume they are stretched or worn at the head... maybe I should just make spacers?
Old 05-01-2017, 03:18 PM   #95
RawhideKid
Why not try these guys?....http://www.fordscript.com/
Old 05-01-2017, 03:23 PM   #96
A31Woody
A31Woody's Avatar
That's a major bummer, Art. I got mine from Snyder's and did not see any obvious issues with them.
I ended up reusing my clevis and just replaced the pins. The replacement clevis would not thread up with my brake rods.
Our 1931 Station Wagon: Originally restored in 1962, redone in the early 1980's, brought back to life in 1997 and refreshed in 2016/2017. Check out the progress at a31woody.com
A31Woody is offline   Reply With Quote
Old 05-01-2017, 03:58 PM   #97
Art Newland
Talked with this guy on the phone, ordered what I need, shipping was 8 bucks. Says their stuff is suitable for point car restorations. A whole set of backing plate bolts (front and rear) for about the same price as just the rears from Bert's. We'll see.
Old 05-02-2017, 11:06 AM   #98
Y-Blockhead
Art, are you sure you have the correct nuts. I noticed on my backing plates that the castle nuts on the rear didn't have the threads all the way thru, the stopped ~1/8" from the end, allowing the bolt shoulder to go into the nut.
Old 05-02-2017, 01:33 PM   #99
Art Newland
My old and new do have the last threads relieved a bit on the end. Bert's is taking back the new ones, no problem. Bert's is going to check the rest of their stock for irregularity. My drivers side will tighten down, passenger will not. They are severely worn, probably weren't tightened down properly.
https://www.youtube.com/watch?v=Gc4y...ature=youtu.be
Old 05-02-2017, 03:17 PM   #100
CarlG
CarlG's Avatar
My garage is affectionately known as the "Alaskan A's Tool Crib"
Alaskan A's
