04-14-2017, 12:19 PM | #21 |
Re: Taking a break for some brakes.
I rebuilt the backing plates and related parts myself but I got Randy's drums and shoes matched. Right out of my trunk and in the garage I cleaned up the drums and painted them VHT black. Over 500 miles they look like the day I put them on and work the same, never have adjusted them since then. And believe me it stops great.
I found Randy Gross after reading about his brakes here on Ford Barn. Randy is very helpful regarding everything brakes. He also has much more in other parts besides brakes, I've been to his shop, gotten a tour and seen his work in progress. Randy is first class in my book and highly recommended. Last edited by denniskliesen; 04-14-2017 at 12:26 PM. |
04-14-2017, 12:19 PM | #22 |
04-14-2017, 12:21 PM | #23 | |
04-14-2017, 12:23 PM | #24 |
Probably should've bought the cutter tool and removed my old drums before shipping, that would've saved some shipping cost.
04-14-2017, 12:26 PM | #25 |
Looks like total, all up, I've spent $1568 bucks.
04-14-2017, 12:43 PM | #26 |
What is the tool for separating the drums from the hubs and how difficult is it?
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
04-14-2017, 12:44 PM | #27 |
You can use a metal hole saw...
As long as it fits around the stud circumference it will cut the swedge Then tap it apart wih a hammer |
04-14-2017, 12:50 PM | #28 |
Thanks Mitch...that doesn't sound too tough......I'll look at it when I get it apart...
04-14-2017, 12:55 PM | #29 |
04-14-2017, 01:00 PM | #30 |
04-14-2017, 01:06 PM | #31 |
If you have the original stamped steel drums, there is a big difference in weight going to the cast iron drums. Big advantage to cast drums and Randy's shoes are brake fade. I plan on going on a tour with a chapter I belong to up in the mountains, Mt. Baldy, in a couple weeks. I have never driven my A with the old original drums and shoes so I won't be able to tell the difference but I'll have the confidence my brakes will get me back down the mountain if I need them.
04-14-2017, 01:44 PM | #32 |
Thanks for the offer.....PM sent....
04-14-2017, 02:44 PM | #33 | |
It sure pays off living in So. Cal. in this case. I live about an hour away, depending on traffic on the I-10, so it will be easy for me as well, when I get to the point where I need new brakes. David Serrano |
04-14-2017, 02:44 PM | #34 | |
Snyder's sells a swedge cutting tool that is suppose to do the job, but at $100 a pop, seems like the freight would be less and just let Randy do the job.
04-14-2017, 02:45 PM | #35 | |
04-14-2017, 02:47 PM | #36 |
04-14-2017, 02:56 PM | #37 | |
Even if I lived as far south as San Diego or north to Bakersfield or beyond I'd haul them down myself. Drop them off with Randy early in the morning and go to a museum or something while you wait. Plan ahead and Randy will work with you. I think he will exchange hubs, backing plates etc as I remember he has rebuilt parts ready to go. |
04-14-2017, 02:59 PM | #38 | |
When I test drove a woman's Model A in St. Paul, I was headed down a long steep hill, and knew half way down that we were in trouble, and would have to glide through the red light at the bottom of the hill. Luckily no cars were coming, and no cop saw what happened. She sold the car rather than fix the brakes. Last edited by Tom Wesenberg; 04-14-2017 at 03:39 PM. |
04-14-2017, 03:03 PM | #39 |
04-14-2017, 03:16 PM | #40 |
I'm past those days of that much excitement! After spending as much money as I had on the engine and electrical, it just wasn't worth taking the chance with bad brakes. Seeing how they looked from the outside with bent up rods broken or missing anti rattle springs and original steel drums along with fellow Model A friends advice I feel I certainly made the right decision. After I got them all off and apart they were half assed in several other ways. Well worth the money spent doing them properly and the piece of mind. Now if only my cheap tires had some traction as the brakes I can lock them up if I want, but it doesn't help getting stopped when you do that.
