12-03-2016, 03:34 PM | #1 |
distributor shaft?? engine oil
i have the remains of three engines that i'm trying to piece together one with. all three have a long shaft in the distributor that reaches all the way down to the oil pump drive. the shafts are all pretty well pitted ad worn. i have several supplier catalogs that show a short shaft in the dist, and a longer one reaching on down to the drive. what is the story on this? i ordered a new upper shaft and looks like i'm going to need the lower one or cut my old shaft into and machine the offset tab and slot in the end.
what type of oil is best to run in these old engines? single viscosity? multiple viscosity? is a zinc additive needed in these old flat tappit cams? |
12-03-2016, 03:45 PM | #2 |
Re: distributor shaft?? engine oil
Do it the original Ford way and order both the top and lower shafts and the collar. Seems someone didn't know why Ford did it this way and they thought a one piece would work fine. They were wrong.
Zink is good for these flat tappet engines. STP has ZDDP added, and I'll be adding that to my engines from now on. |
12-03-2016, 04:07 PM | #3 |
What oil do I use has been spoken about here till it's been flogged to death. I suggest you do a search on it and settle in for a long read.
As I understand it, ZDDP is good on a cast cam shaft but not really needed on a steel one (or is it the other way around??) What ever, I don't use it and I've done lots of miles on the same engine. Do as Tom says about the distributor shaft.
12-03-2016, 05:43 PM | #4 |
Buy the top distributor shaft with the oil hole in it from Snyders.
Just screw off the cam screw and squirt some oil down the hole of the shaft and replace the cam screw. Pretty simple; pretty nice.. Mobil 1 10W30. Has all the bats wings and file handles in it..
Good enough.. Isn't. |
12-03-2016, 06:08 PM | #5 | |
Do as Synchro909 suggests, if you really want to see a zillion comments on this subject and be really informed ! Multiple viscosity is the way to go , if you are concerned with interior engine cleanliness. Full oil filter goes with this theme also. Only thing that I can add to dist shaft comments already given, is that before installing shaft into engine, coat it with a LOT of good sticking lube, like antiseize (?). Anyone pulling such shaft out of a used engine will notice large amounts of rust in the hole and on the shaft. I try to coat the entire area with protective coating..it seems to work for me. Condensation WILL get to any uncoated areas exposed to it. |
12-04-2016, 12:27 AM | #6 | |
12-04-2016, 01:05 AM | #7 |
Any oil, of the proper weight, that is designed for motor vehicles will work fine in your engine.
12-04-2016, 09:50 AM | #8 |
From Snyder's Antique Auto
12-04-2016, 09:57 AM | #9 |
i am going to order the lower shaft, at about $3.00 it aint worth the effort to make one. i'm just curious as to why three random engines all have the long shaft. they must have been used in production at some time. i will do a bit of searching on the oil question. i read some comments on here at some time to the thought that any modern oil is better than what was available many years ago. also that the a cam is steel rather than cast and you don't really need the zddp. it sounds like it comes down to personal choice.
12-04-2016, 10:11 AM | #10 |
The long shafts are reproductions made by Vendors who were trying to save a few pennies..
Henry knew..
12-04-2016, 10:28 AM | #11 |
Im trying to think of the last time we heard of someone wiping a cam lobe or lifter out?
12-04-2016, 12:30 PM | #12 |
Larry as the others said, the one piece long shaft was a Western Auto special from the past........best to stay with the original Ford two piece design. That acts like a bit of a 'u-joint' setup to compensate as an 'adjustment from what I was always told.
Buy the shafts from Bratton's or Snyder's, good quality. I started pulling the dissy every spring as regular maintenance and smearing Never Sieze with graphite on the shafts to help prevent rusting and keeping the distributor from getting permanently 'chummy' with the head! Keeps you from having to bear down someday with a dist. body puller, making swapping out the distributor a lot easier. |
12-04-2016, 03:59 PM | #13 |
I must have received an original screw somewhere along the way. I clearly remember drilling it. Seems someone else had the same inspiration before me.
12-04-2016, 04:38 PM | #14 | |
12-04-2016, 04:39 PM | #15 | |
12-04-2016, 07:09 PM | #16 |
if the long shaft was an after market item from western aut they must have been popular,at least i now have some insight as to what i have. thanks
12-04-2016, 07:43 PM | #17 |
My dad owned and operated a Western Auto for 50+ years! He said at one time WA had all the parts to build an A except for the frame. That was before my time :-)
Thread Tools | |
Display Modes | |
