05-23-2016, 04:40 PM | #81 |
Re: Ford Model A & B Motors
Tom Wesenberg & George Miller -- Thanks for the information to help me get my all this new stuff in a row. I am just finishing Van Pelts book on transmissions along with my 3rd pass on Mr B book, still finding more stuff each pass.
06-02-2016, 12:49 AM | #82 |
What is the CFM on a 97 & 81 Carb?
I have always used 94 carbs that flow 150 cfm, are 97 & 81 a better choice for the motor build I am planning? Motor build is listed in this thread. I want to use 2x2's or 3x2's setup. Last edited by old28; 06-05-2016 at 04:21 PM. |
07-19-2016, 07:00 PM | #83 |
What color of dark green can I paint my A engine? Not looking for a restore color just one that looks nice and can be brushed on. Want the same color on pan, block & iron head.
07-19-2016, 07:33 PM | #84 |
The Ford engine green paint is available from most of the usual Model A vendors. It comes in both a pint can and spray rattle can.
07-19-2016, 08:52 PM | #85 |
07-20-2016, 08:17 AM | #86 |
Is there one brand that holds up better? The pan will be "BLACK" |
07-22-2016, 01:32 AM | #87 |
Speed costs money. How fast do you want to go?
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
07-22-2016, 07:18 PM | #88 |
Chris --- Already went fast & spent a ton of cash.
This is about the build & having a project to work on. |
12-21-2016, 12:37 PM | #89 |
Just got my model A motor and have started to pull it apart. I do have a question on the valve train side cover. I have seen a few cast aluminum side covers that are not set up to use the stock oil return tube on the side. my motor has a small hole in the case at the front that returns oil to the front of the cam bearing.
As this motor will be used for 1/8 mile sand (Trog) racing only with limited run time, will it be ok to run a none return oil tube side cover? |
12-21-2016, 03:34 PM | #90 |
Yes it has been done before
12-21-2016, 10:15 PM | #91 |
colin1928 -- Thanks for the reply. Good to hear, I was hoping that was the case as this will be a fresh built motor and should not be using more oil than normal for regular lubrication. I would like to run a 5 or 6 rib cast aluminum side cover. If I find one that is setup for the oil tube I will run it.
08-10-2017, 11:31 AM | #92 |
Hey old28 how did the engine build come out? I stumbled upon the thread looking for piston to bore clearances.
I'm in NJ and building for TROG 2018, I've been a spectator for far too long. |
