Old 12-11-2014, 03:40 PM   #81
Brentwood Bob
Default Re: Not Charging - what's up?
you can replace the rope packing with the lead foil packing on the waterpump.
bob
Brentwood Bob is offline   Reply With Quote
Old 12-11-2014, 03:40 PM   #82
Big hammer
And the EVR works very well Tom did mine and i'am very pleased :-)
Big hammer is online now   Reply With Quote
Old 12-11-2014, 06:10 PM   #83
Tom Wesenberg
Tom Wesenberg's Avatar
bob
Yes, the lead packing rings are the way to go. Pull out the old stuff and install 2 lead packing rings with lots of grease smeared on them. I did mine about 12 years ago, and it never leaked a drop, and I only tightened it a couple times in 12 years.
Old 12-11-2014, 06:25 PM   #84
Purdy Swoft
Purdy Swoft's Avatar
I agree there needs to be plenty grease around the packing inside the packing nut . Without the grease no packing of any type will stop the leak .
Old 12-11-2014, 06:28 PM   #85
Purdy Swoft
As for the generator It may just be a good time to replace it with a rebuilt , plus the ammeter
Old 12-12-2014, 09:19 AM   #86
Walt Ebie
Walt Ebie's Avatar
That's way I've decided to go...rebuilt gen, new ammeter and the packing rings you all mentioned. After that I'll deal with the short in the light switch that causes high beams to blow the fuse. Whoever it was that said, "If you're going to have a Model A.....be prepared to be your own mechanic," was just about right, or so it appears. But we still love our car anyway.
Walt Ebie is offline   Reply With Quote
Old 12-15-2014, 04:22 PM   #87
Walt Ebie
Walt Ebie's Avatar
So here's the current progress report: A trip to Snyder's (an hour away) to get an generator and some lead-graphite water pump packing rings.....a little time to put it back together again.....all systems are 'go'! Generator output now about 9v....ammeter shows the same. Since I put in the last of the rope-graphite packing I had the water leak seems about gone so I'll save the rings for another time. And, again, my great THANKS to all those who gave some time and thought to my charging problem - especially Tom Wesenberg, MitchPA, and all the rest! I've learned a bun ch in the process.
Old 12-15-2014, 04:40 PM   #88
Tom Wesenberg
String packing is used for slow turning shafts, like your water faucet.
The lead packing rings (with grease on them) are used for fast spinning shafts.
The string packing can wear a groove in the shaft.
Old 12-16-2014, 12:18 AM   #89
Mike V. Florida
Mike V. Florida's Avatar
Originally Posted by Walt Ebie View Post
I've learned a bunch in the process.
That's the important thing along with those that read the thread and also now have ideas on what to do if a similar thing happens to them.
