Old 09-06-2014, 04:17 PM   #1
Clydes 31 P/U
Default Old trouble light or old light trouble
I pick up this old trouble light at a yard sale for a buck (guy said switch was broken), the switch is fine, but there was no bulb, that's why it (the switch) felt broken. The black parts are wood, the cloth covered wires need to be replaced, the body is plated brass and has a glass lens, the adapter on the end replaces a single filament bulb in a tail or a dash light socket. The question I have is what is the number for a 6v, 2 filament bulb with the locator pins directly across from each other and where would I be able to find one, if there is such a thing? I filed the upper pin off an old 12v bulb to see if that was an option but the switch pushes the bulb out of place. The 2 pins in the last photo turn and make contact with the nubs (for lack of a better word) on the base of the bulb one for ground one for the hot. Thanks for any information, Clyde
Clydes 31 P/U is offline   Reply With Quote
Old 09-06-2014, 05:55 PM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Old trouble light or old light trouble
Dog here,
Sounds like too much "TROUBLE", jist hang it on the wall"!
Buster T.
"THE ASSISTANT GURU OF STUFF"
Old 09-06-2014, 08:43 PM   #3
Spokes
Originally Posted by BILL WILLIAMSON View Post
Dog here,
Buster T.
Dog, that is just sooo wrong !!!! Lol
Spokes is offline   Reply With Quote
Old 09-06-2014, 10:47 PM   #4
Mike V. Florida
Mike V. Florida's Avatar
This may help with the restoration,
http://www.sundialwire.com/
Old 09-07-2014, 12:47 AM   #5
45GPW
45GPW's Avatar
I think you want a single filament lamp with a double contact bayonet base, not a 2 filament. Most 2 filament lamps ground to the shell.
You'll probably also need a lamp with a G shape bulb (globe shape) to fit under the lens.
A number 64 or 82 lamp will probably fit the bill. Both are 6V rated automotive lamps. The 82 will probably be easier to find.
45GPW is offline   Reply With Quote
Old 09-07-2014, 01:10 AM   #6
Mike V. Florida
This seems like a good bulb to try;
http://www.bulbtown.com/88_MINIATURE..._BASE_p/88.htm
Old 09-07-2014, 01:33 AM   #7
45GPW
45GPW's Avatar
Measure from the bottom of the socket to the lens to see if it will fit before ordering. The 88 is 2" maximum overall length. The 64 and 82 I suggested are 1-7/16" max. overall length.
Old 09-07-2014, 06:18 AM   #8
Clydes 31 P/U
Thanks, I will check them out.....Mike, the sundial wire suggestion is great, I was going to use some cloth covered wire I have but the twisted pairs are perfect!! 45GPW, I will definitely measure for clearance, Thanks again........Clyde
Old 09-07-2014, 10:25 AM   #9
jrelliott
jrelliott's Avatar
Try donsbulbs on the internet. He has a listing of all bulb types and the dimensions, base type, voltage etc.
jrelliott is offline   Reply With Quote
