06-25-2013, 02:47 PM | #61 |
Re: Motor UPDATE!!! It aint pretty
George or Herm,
How much offset in the " cylinder bore center line to main bearing bore center line" in an "A"? Is the "B" the same? Also, which way....viewing the engine from the front? I would think the crank to the right? It will change the torque characteristic of the engine. Is that normal practice to run the offset pistons to the front or the rear in an A with Chevy pistons, engine builders? I also don't think that is the cause for what we are looking at here tho. |
06-25-2013, 03:02 PM | #62 | |
It was not intended as sarcasm, this is not the first time this/a 'youngster' has threatened to 'chop it and make it a rod'. Albeit not my first choice for a nice car, I welcome the original parts when he/they decide to do so. Last edited by Steve Wastler; 06-25-2013 at 03:11 PM. Reason: add smiley face |
06-25-2013, 03:26 PM | #63 | |
A point that has not been discussed regarding all the comments about wrist pins being too tight. These are Hypereutectic pistons that come with the wrist pins supposedly machined & fitted to the piston from the factory. The connecting rod is to be heated and the wrist pin is inserted into the rod for an interference fit. If the pins were indeed fitted at the factory, how does this play into the thought of wrist pins too tight? Also one other thought regarding pistons too tight. It is reported this engine had a #4 piston failure early on due to overheating. The engine builder supposedly pulled the engine down under warranty and rebuilt the top-end of the engine only charging for parts (no labor or machine shop charges). Since 4 new pistons & rings were installed, and the cylinder walls (sleeves) had to honed again (to clean up the galling), a good argument could be a be made that the piston-to-bore clearance was well within spec. by the time the second honing was done. Thoughts on this?? . |
06-25-2013, 03:33 PM | #64 | |
Thread Tools | |
Display Modes | |
