06-25-2013, 12:01 AM | #41 | |
Re: Motor UPDATE!!! It aint pretty
06-25-2013, 12:13 AM | #42 |
Lawn mowers with similar problems & the part where to rod does not move very far under its own weight, i am not an expert on those though, this is the internet afterall so it would be hard to give an accurate diagnosis but yeah.... & all the sloppy pins in worn out engines i had over the years might make me bias.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
06-25-2013, 06:34 AM | #43 |
06-25-2013, 06:56 AM | #44 |
Wow, this just keeps getting uglier!! . |
06-25-2013, 07:14 AM | #45 |
Yes, quite, I was not going to post about all this drama. I do get tired of 'the age thing' thrown around here by misdirected kids. Less originals will undoubtedly make the rest worth more! I will always take the cast off original parts.
06-25-2013, 07:22 AM | #46 |
06-25-2013, 08:56 AM | #47 |
To me it looks like that cylinder has a sleeve ---not that it is the cause of the problem ,but that it has to be considered in working on a solution --it may not be good to bore it larger because the sleeve can get too thin although most likely removing the deposited piston and honing (with rigid hone not glaze breaker or dingle berry hone)can fix that bore.
There doesn't look to be signs of heating at the wristpin, I doubt that is the root cause, that piston got distorted by the heating of the skirt, the wristpin will not fit as it was assembled ---it will be hard to know what clearances it was assembled with, although comparing the bore size with the other bores can give clues Measure the bores, top middle and bottom, if you don't have proper measuring tools you can get an idea with a piston ring by measuring the end gap, the changes in bore size are about 1/3 the change in ring end gap. Did you have an oil filter? --I remember it being mentioned in one of the posts, but I don't remember if it was installed |
06-25-2013, 09:08 AM | #48 |
And the good news is that the con rod dipper tray has not been drilled.
Henry J. Kaiser said that problems are opportunities in work clothes. Judge Joe or Judge Judy ?? I have been in the business for more years than I care to reveal. I once installed a factory long block into a car, took it for a road test and had a con rod force its way through the side of the block. These things happen and have happened since machinery has been around. The way I handle it is to leave it alone for an undetermined amount of time and when I get back to it my thought processes are less clouded and then I can figure out the best way to handle it. Chet |
06-25-2013, 10:20 AM | #49 | |
Kahuna & Phil, Morning.. The engine builder, builds the engine...and in this case installs it in the car. After that, the owner has control of the car. Hopefully the builder is sharp enough to check the radiator, water pump and the distributor. How was the car driven?? To do that much damage to the piston, it didn't happen instantly. It took time...the engine was "sagging"...working hard to compensate for a "hole" that was tightening up. The water temp is going to go up. The engine is going to "shake". It's a 4 cylinder engine....how much harder does 3 holes have to compensate(work) for a stuck hole! This all shows up in the main bearings in the photos. To bad no photos of the rod bearings....odd? Hope this helps you juveniles.... |
06-25-2013, 10:53 AM | #50 |
Dudley, also take into consideration this engine is reported to have 1,500 miles on it. Think about how long that is in terms of driving time. I would also assume this does not account for idling time or waiting at traffic lights or stop signs. If I recall correctly, the OP mentioned something about this engine being driven at 75mph. Driving this engine 1,500 miles at a "killer" speed of 75mph still would take 20 hours of operation to do. Process all of that for a moment or two!!!
06-25-2013, 11:02 AM | #51 | |
Cowtown A's |
06-25-2013, 11:04 AM | #52 |
The way that I read it was that the engine builder bragged about running the car at 75 mph while testing. The owner actually thought that running the engine at 75 MPH before break in was not a good thing.
06-25-2013, 11:07 AM | #53 |
[QUOTE=BRENT in 10-uh-C;676735]Wow, this just keeps getting uglier!!
If you look at your calendar you will see we had a FULL MOON recently, makes people crazy. Bob . |
06-25-2013, 11:17 AM | #54 |
you read it correctly.
Cowtown A's |
06-25-2013, 11:53 AM | #55 | |
I wouldn't even think of doing that to a well broke in engine. I'm still wanting to see a picture of the odd shaped counterweights. |
06-25-2013, 12:00 PM | #56 | |
When you have a melted pistion like that, it can go from good to bad in 30 seconds with out warning. From no noise, to what you see. We have had several engines come in like that from other builders, and the owners, all have there stories of how the engine acted, and stoped, and they are all about the same. It just doesn't happen, you can always find the cause. I have never used those kind of pistons, and don't intend to. But George gave a good clue to look for with the way you install them, and the wrist pin bosses. Last edited by Kohnke Rebabbitting; 06-25-2013 at 01:13 PM. |
06-25-2013, 12:33 PM | #57 | |
[QUOTE=Bob C;676906]
I've got to agree!!! We saw the same sort of thing on the New project in my shop, thread . Same bullies involved. |
06-25-2013, 01:09 PM | #58 | |
Some things should not be changed! 75MPH is plain nuts on a new Model A engine. That's just common sense. |
06-25-2013, 01:24 PM | #59 |
If you want a Chevy engine & want to do 70-75 MPH in a model "A" with air condition, four speed trans, & high speed rear end , Call Rick Hendricks !!!..
06-25-2013, 01:36 PM | #60 |
