04-27-2013, 09:06 PM | #41 |
Re: sparks around spark plugs...
Try running a ground wire from the condenser ground screw to a good ground on the engine. A good clip lead will do.
04-27-2013, 11:00 PM | #42 |
This is like a "SUSPENSE DRAMA", now we have twiddle our paws for a whole WEEK! You know, to a Dog, that's equal to 56 DAYS! If only Ol' Whatzhis name, (My pet Man) would get that TRAP runnin' maybe I could endure the wait? Buster T.
04-27-2013, 11:38 PM | #43 | |
Wow. Real head scratcher. OK, a new clue emerged in your last post. You shouldn't see a spark "through" the spark plugs. Since the inside of the plugs is a solid metal conductor, the spark should travel along it and not be illuminating through the ceramic. It sounds like severely corroded plugs now. Since you know how to do conductivity testing, what is the resistance from the top of the plug to the center electrode inside the plug (where the spark jumps while inside the motor)? Should be 0 ohms. |
04-27-2013, 11:44 PM | #44 |
How old are the points? I don't mean how long since you installed them but rather do you know when they were bought new?
I ask because a couple of years ago I remember owners complaining of missing at high RPM and the problem turned out to be week spring holding the points to the cam. as the speed increased the points would no longer ride on the cam and bounce so as not to close each time. A shot in the dark, I know.
04-27-2013, 11:51 PM | #45 | |
Yes, that's a real good point. However, that wouldn't explain the "light show" he's experiencing. |
04-28-2013, 12:05 AM | #46 | |
That's why I thought of the points bouncing. Is it the problem? I don't know just trying to help.
04-28-2013, 12:13 AM | #47 |
You obv still have HV leaking to ground and you are aware of it. Under the circumstances all your eval must now be done in the dark to truly know what is going on.
You've pulled the plugs and cleaned them incl the porcelain and they still bypass voltage to ground. And the coil wire is "new" but some ignition wire is junk, so beware of that. I've had 'new' ign wire leak spark like crazy. 10,000 volts is a lot to hold back. Charlie Kettering was a genious when he designed the L-C circuit which we have come to know as a points- based system. He knew what he was doing and how to get the voltages needed to jump a gap, and he put the earlier magneto systems out of business. And he was untouched for nearly 100 yrs until electronic ignition was born. Too bad he worked for GM and not Ford. Since this started with a cleaning, I am gonna suggest you install a new set of plugs and get a length of ultra modern silicone coil wire at least for the time being. Porcelain under a microscope looks like cinder block (cement block)...meaning very porous. I think the pores are contaminated beyond cleaning. The grounding discussion is interesting but 10,000 volts will find its way to ground, never worry about that Tom is very correct about the formation of carbon tracking on plastic and bakelite (the first plastic) parts such as dizzy caps. Once it forms it will always return to the same place no matter how well you clean it. The part must be replaced. Not sure this is your problem right now, just wanted to second Tom.
'31 180A |
04-28-2013, 07:04 AM | #48 |
You need to change the plugs. Don't clean them, change them to new. You shouldn't have sparks around the plugs. Not only is it making your engine run bad but in some cases it is dangerous.
04-28-2013, 07:27 AM | #49 | ||||
Back at it next week... rob |
04-28-2013, 08:28 AM | #50 |
I agree with the plug change. Iff'n yours are old their may be very small porous cracks in the porcelain. When you cleaned them you could have pushed enough material into the cracks to create a path to ground. I do not think this is a fuel issue, unless there is another chapter to the story regarding the carburetor. The problem started when you cleaned the engine. Something changed at that time. Choking the carb to make it run better is a red herring.
Sounds like a good problem to run a contest around....
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain. It is the very things that we think we know, that keep us from learning what we should know.- Unknown |
04-28-2013, 09:06 AM | #51 | |
04-28-2013, 09:19 AM | #52 |
hello
what is the differance in the w16y and the w18y and what is best to use kevin 1930 mo9del a tudor 1923 model t roadster p/u |
04-28-2013, 10:26 AM | #53 |
Temperature range. I use the W18Y because they are a bit hotter.
04-28-2013, 10:38 AM | #54 |
I agree, I would think the local auto store should have the correct sparklers including 3076 or 3077 Autolite. The 3077 being a tad hotter than the 3076 just like the W18 is hotter than the W16 and I prefer the hotter. I prefer Autolite to Champion in just about any application, but, thats just my opinion. The Champions certainly look better though.
04-28-2013, 02:58 PM | #55 |
Might even find some TT10's.
04-28-2013, 04:53 PM | #56 |
04-28-2013, 06:15 PM | #57 |
Try NAPA..................
Paul in CT |
04-28-2013, 06:28 PM | #58 |
Nobody around there owns an N series tractor? Try a local n on chain auto parts.
04-28-2013, 06:36 PM | #59 |
N series tractor has a plug that is way smaller than a model A. It is the same as a 40 or so flathead Ford.
04-28-2013, 06:55 PM | #60 |
