Old 06-28-2020, 08:45 PM   #1
JLford
JLford's Avatar
Default 1951 8BA Cooling Capacity
Hi everyone,
I recently replaced the heater core in my 1951 Ford Victoria.
The green bible says my engine should accommodate 5 gallons of coolant, yet I was only able to fill it with just shy of 4 gallons.
The heater control valve is functioning, and the thermostats didn’t show signs of failure prior to the heater core replacement. Has anyone else encountered this capacity discrepancy?
Thanks!
JLford is offline   Reply With Quote
Old 06-28-2020, 09:16 PM   #2
leon bee
Default Re: 1951 8BA Cooling Capacity
I can get a little more than 5 gallons in each of mine. Is your rig all stock?
leon bee is offline   Reply With Quote
Old 06-29-2020, 12:53 PM   #3
rotorwrench
rotorwrench's Avatar
When you drain the cooling system, there can be coolant that remains undrained.
Old 06-29-2020, 02:50 PM   #4
Ross F-1
Ross F-1's Avatar
My truck (with Car heater) lists at 22 qts, I've never gotten more than 18 - 19 in, even with a dry block (after rebuild).
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 06-29-2020, 03:56 PM   #5
40cpe
40cpe's Avatar
Maybe it is the radiator differences among different applications. My '38 has a stock type 4 row radiator and I put over 5 gallons in it when installed after the build. I think the upper tank on these radiators could easily hold 2+ qts.
Old 06-29-2020, 05:05 PM   #6
Ronnieroadster
Ronnieroadster's Avatar
On the 8BA thats a fact plenty of coolant remains in the bottom of the block on both sides. Unlike the 59A and earlier blocks that have the drain valve on the lower pan rail of the block which allows all of the coolant to drain out. The 8BA will not drain all the coolant unless the water pumps are removed and the small hole located near the bottom on the face of the block is cleaned out then the block will drain all the way. Many 8BA blocks can be found with cracked pan rails caused when the water froze that remained in the block after the water pump hose was removed.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is online now   Reply With Quote
Old 06-30-2020, 02:17 PM   #7
Ross F-1
Ross F-1's Avatar
Ronnieroadster
Even with the pumps out, with the engine in the frame, the 3° slope to the rear keeps some at the back. Need to lower the front to get it all.
