Old 05-20-2015, 06:50 PM   #1
d.
Default 5w/20 oil OK to use?
yes I am hanging on... I have several cases of 5w/20 left over from a modern car we sold.
Can I use it in my Model A, unknown history, runs well, no smoking?
Should I blend it with straight 30w, or is it OK on its own? Maybe a little STP additive?
d. is offline   Reply With Quote
Old 05-20-2015, 06:54 PM   #2
Mitch//pa
Default Re: 5w/20 oil OK to use?
i wouldnt use it or mix it with anything to use it.
if you were close by i would take it off your hands, as many newer cars spec for that
Old 05-20-2015, 07:11 PM   #3
billwill
I would not use in a Mural Asell it to friendwrong oil for that car goodluck
billwill is offline   Reply With Quote
Old 05-20-2015, 07:54 PM   #4
harleytoprock
Too thin !
harleytoprock is offline   Reply With Quote
Old 05-20-2015, 08:05 PM   #5
JD 1931
JD 1931's Avatar
Too thin for me, I use 20w 50w in mine, hot down here..
JD 1931 is offline   Reply With Quote
Old 05-20-2015, 08:52 PM   #6
Synchro909
Synchro909's Avatar
I'd use it maybe with some viscosity stabiliser added to make it more viscous. It is no doubt of higher specs than what a Model A needs (as are all of the modern oils.)
Although it is much thinner than what most of us use, it no doubt would keep the metal components apart.
When building a high performance motor, it is important to have as much oil flowing through the bearings as possible (to cool them). Might even find that it is better than thick oil. It is worth noting that oil film strength is not so closely related to viscosity as it used to be because of the additives they put in there nowadays.
I bet I get lots of feedback on that one!!!
Old 05-21-2015, 12:37 AM   #7
M2M
M2M's Avatar
Crossing Russia mid-winter I MIGHT use it.
M2M is offline   Reply With Quote
Old 05-21-2015, 02:21 AM   #8
Charlville
Charlville's Avatar
I've got a mix of 20/50 and 10/40 in mine
Kevin Flood
West Berkshire UK
Member MAFCGB, VHRA, SAH, Brooklands Trust
Sporadic progress on My 1929 Sport Coupe can be found here along with my blog
http://automotiveamerican.com/
Charlville is offline   Reply With Quote
Old 05-21-2015, 11:16 AM   #9
Patrick L.
Patrick L.'s Avatar
Why not use it in your 'modern' cars ? Most cars within the past decade call for that [ if not full syn].
I wouldn't use it in an 'A'.
I also don't believe in additives like STP or mixing oils.
Old 05-22-2015, 01:30 AM   #10
Allanw
Allanw's Avatar
If it were 5W-30, it'd be perfectly fine, but 5W-20 MAY be a little light when hot.
Allan
'29 Tudor, Canadian RHD
Whangarei, NZ
"Duct Tape can't fix stupid, but it can MUFFLE the sound"
Allanw is offline   Reply With Quote
Old 05-22-2015, 02:13 AM   #11
dumb person
dumb person's Avatar
Should be fine in winter.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 05-22-2015, 03:49 AM   #12
C26Pinelake
I would sell it and use the proceeds to buy a more suitable oil.
Wayne
C26Pinelake is offline   Reply With Quote
Old 05-22-2015, 07:29 AM   #13
prpmmp
When its hot its all the same,its thin when cold(great for startup) Pete
http://www.bobistheoilguy.com/motor-oil-101/
prpmmp is offline   Reply With Quote
Old 05-22-2015, 08:27 AM   #14
Dollar Bill
Dollar Bill's Avatar
I'm not a smart man but I do know that the 5W20 specd for newer cars pours like water and the 15W40 is more viscous. This leads me to think the thicker oil would do a better job filling the gap between moving parts when running and not drain away when the engine is shut down.
I can imagine late model engines can get away with thinner oil due to tighter clearances and a better oiling system than engines that were designed in early 1900's.
I have to agree with most of the responders to this thread - Use the 5W20 in newer cars as called for by the engine designers.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 05-22-2015, 10:42 AM   #15
V4F
V4F's Avatar
I would not use it in my lawn mower !
V4f
V4F is offline   Reply With Quote
Old 05-22-2015, 02:16 PM   #16
Fred K-OR
Fred K-OR's Avatar
Not knowing much about this question but I would agree with this comment. It would seem like where you lived and what time of year is was.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 05-22-2015, 04:51 PM   #17
Rocketsled
Rocketsled's Avatar
Modern low end multi-viscosity oils enable new car makers to achieve the MPG figures required by Gov.
In an A, I use SAE 30HD. I would switch to SAE 20 HD if cold weather
usage is planned.
Old timers who came into our family Texaco in the 1950's used SAE 20
year 'round in southern New England.
Rocketsled
Rocketsled is offline   Reply With Quote
Old 05-23-2015, 01:23 AM   #18
Allanw
Allanw's Avatar
No - the second number refers to the hot viscosity, as your link states.
Allan
Whangarei, NZ
Old 05-23-2015, 09:32 AM   #19
prpmmp
Opps!! Being stupid is not against the law! It's mighty unhandy once in a while Pete
Old 05-23-2015, 03:35 PM   #20
Allanw
Allanw's Avatar
I think the guy who came up with the "system" should be shot! there are far easier ways, that would be easier to "get".
MOST people (inc mechanics and piles of people on here) still don't understand it (even if they think they do )
Allan
Whangarei, NZ
