Old 10-27-2019, 08:00 AM   #1
patbill@megahits.com
Smile Fog light location
Hi,
I bought a pair of (correct) fog lights at Hershey a few weeks ago. I will be installing them on my 48 Mercury convertible. They mount on the filler panel between the bumper and the grill. Does anyone know how far apart they should be? If the distance between them is too close or too far, they will look weird. Any thoughts on the best distance between them?
Thanks!
Bill in Conn.
patbill@megahits.com is offline   Reply With Quote
Old 10-27-2019, 08:24 AM   #2
Kube
Kube's Avatar
Default Re: Fog light location
Bill, I am confident someone with a lot more knowledge of 48's will weigh in here.
I think the correct lamps mount above or directly next to the bumper arms and are supported via the mounting hardware by the arms.
It seems difficult (to me) to believe they would simply mount on the metal pan.
Old 10-27-2019, 09:14 AM   #3
Gary in La.
Gary in La.'s Avatar
The correct fog light brackets have a clamp that clamps on to the bumper arm. Many times the lights are sold missing the brackets or have the wrong generic type.
Gary in La. is offline   Reply With Quote
Old 10-27-2019, 09:49 AM   #4
Kube
Kube's Avatar
Thanks for coming forward with your expertise. What you posted is exactly what I thought.
Old 10-27-2019, 11:20 AM   #5
Thanks! I don't have the brackets but I can make two. The extra support with brackets makes sense to hold them tight. It also tells me where to position the lights. As always, really appreciate the help!
Bill
Old 10-27-2019, 12:41 PM   #6
blucar
blucar's Avatar
The correct mounting brackets are the most important part of accessory driving/fog lights. The correct brackets generally clamp onto the bumper bars, then the lights bolt onto the brackets.
Generally there are several good bracket sets listed on eBay..
Bill.... 36 5 win cpe
blucar is offline   Reply With Quote
Old 10-27-2019, 02:00 PM   #7
Gary in La.
Again, beware of the generic fog light brackets on Ebay which are usually a cast version the doesn't sit below the front pan to support the light. The correct ones are a 90 degree bend and have a backing plate that sandwiches the bumper bar. I've had several sets but I can't locate a picture. Below is a picture of the backing plate that is used. this will give you some idea of what to look for.
Old 10-27-2019, 10:06 PM   #8
slowforty
slowforty's Avatar
Years ago the Late Great Lloyd Duzell Restored a 48 Mercury convertible with Fog Lights mounted in the outer ends of the grille. I twas supposed to be a Rare accessory
slowforty is offline   Reply With Quote
Old 10-28-2019, 06:11 PM   #9
Thanks again for all of the input. It is great information.
Bill
