04-11-2016, 08:22 AM | #1 |
Model A Rear Wheel Bearing
Does anyone have an actual model # or Timken number for a rear wheel bearing?
1929 Model A Ford Coupe |
04-11-2016, 08:32 AM | #2 |
Re: Model A Rear Wheel Bearing
I was told by the local Timken franchise that they do not make a bearing for the rear wheel of a Model A. Wayne
04-11-2016, 08:53 AM | #3 |
I seen to recall someone listing it here just a few weeks ago. I wonder if a search would turn it up?
04-11-2016, 09:03 AM | #4 |
Thanks Tom, I did not know that was just talked about. Appreciate it, I'll look.
04-11-2016, 09:27 AM | #5 |
Yes I saw the thread where I believe Mike posted some PDFs, great info. I saw some other numbers, but unless I missed it I did not see any Timken info, so my apologies for asking again, but I didn't know if there was a specific Timken number for the rear wheel bearing for a Model A 28-31? I am seeing lots of things searching online, but not 100% sure what is correct. Thanks.
04-11-2016, 09:36 AM | #6 |
04-11-2016, 09:43 AM | #7 |
I thought the number was mentioned in the recent thread about the rear wheel bearing that went bad, but that thread is already back on page 6. I went through it twice and didn't find the number.
Our local bearing and seal store is good for these things, but I just called Paul and he didn't know the number and said it was too old for him to look up. |
04-11-2016, 10:04 AM | #8 |
Unless your in a big rush, why not just order bearing from Snyders or choice of parts suppliers. Snyders is in Springfield.
04-11-2016, 10:06 AM | #9 |
Because if I can get it through Napa I can get it much cheaper, that's the only reason.
04-11-2016, 10:32 AM | #10 |
It is a Hyatt number not Timken. I have been looking for the Hyatt number used in the 30's and 40's as I often find NORS bearings at local auctions. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!! |
04-11-2016, 10:43 AM | #11 |
If NAPA can get the bearing, then I'd think they can look it up. I just tried a Google search for the number and still haven't had any luck either. My original bearings have always been good, so I haven't had to buy a replacement. I just looked in two catalogs and didn't realize the bearings were so expensive, at $42 each. That's why it's so expensive to rebuild rear ends with all new bearings.
04-11-2016, 10:57 AM | #12 |
There is no Timken number for that bearing. Ford B-1225, Bower J66-3657,
Hyatt 00536, SKF 00536. Bob |
04-11-2016, 11:00 AM | #13 |
Ok so Timken did not or does not make a rear wheel bearing for the Model A's?
04-11-2016, 01:12 PM | #14 |
04-11-2016, 11:05 AM | #15 |
Copied this from ?? a while ago: J-662456 Federal Mogul BCA is the correct size for the Model A rear hub straight roller bearing.
04-11-2016, 11:15 AM | #16 |
You should be able to order from an industrial distributor.
04-11-2016, 12:51 PM | #17 | |
They use it when installing the sleeve in a worn Model A hub, it has a smaller OD and width. J66-3657 (B1225) ID 2.0625 OD 3.1875 W 1.7188. J66-2456 (68-1225) ID 2.0625 OD 2.813 W 1.670. Bob |
04-11-2016, 12:28 PM | #18 |
The J-662456 rear wheel bearings mentioned above are on Ebay for about $28.00 with no picture of same.
About (7) years ago I noticed that I had a pitted rear wheel bearing race. I had a new hardened sleeve installed on same. Then, I ordered a Model A rear wheel bearing from a very popular Model A parts supplier; however, the rollers were smooth with no spiral recessed grooves like originals. Old bearing looked fine, so I reinstalled the old bearing with spiral grooves. Have no idea if "all" new rear wheel bearings have spiral grooves or not. Last edited by H. L. Chauvin; 04-11-2016 at 12:29 PM. Reason: typo |
04-11-2016, 04:38 PM | #19 | |
04-11-2016, 04:13 PM | #20 |
Has anyone had any luck on buying the grease seal for the rear wheels at any local stores?
